First time using LED's
- mekanic13
Here are a couple of signs I just finished using LED's. One is powered with a 9 volt battery and the other with a transformer.
- Attachments
- IMG_20131228_203545 (500x474).jpg (198.43 KiB) Viewed 2857 times
- IMG_20131228_203415 (500x436).jpg (112.28 KiB) Viewed 2857 times
- IMG_20131223_141518053 (465x500).jpg (281.7 KiB) Viewed 2857 times
- IMG_20131223_240421096 (439x500).jpg (245.68 KiB) Viewed 2857 times
Re: First time using LED's
They look good.
Did you break the current with a switch on the battery powered one or do you have to just unplug the battery?
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
- mekanic13
On the battery powered one I put a push button switch on the side of the sign. The 9 volt battery is mounted inside the sign.
Mike
Mike
- Craig
Nice signs what is your amp usage and how long does the 9v last? Craig Johnson
Craig Johnson
- mekanic13
Thanks.
The amp draw for the small sign is 15mA per led and I'm using 8 so that's 120mA. Really don't know how long the 9 volt will last, kinda went by the seat of my pants with that one. The large sign is drawing 300 mA for the green portion and 120 mA for the white portion for a total of 420 mA.
Mike
Mike
Looks great! I'm looking at using phosphorus lights on a project that will be both solar and battery powered. There are some nice options available for lighting. Thanks for posting the pics.
Dave Hanks
Dave Hanks
- mekanic13
Thanks Dave,
I'm not familiar with phosphorus, how do they compare with LED's? The solar part sounds interesting.
Mike
Mike
good looking signs
Guys where do you but your LED lights and supplies?
Thanks, Dawg
Thanks, Dawg
Opps where do you buy your LED lighting and supplies?
Dawg
Dawg
