2x72 belt grinder build.
weldor2005
Re: 2x72 belt grinder build.
Post by weldor2005 »
CNCCAJUN wrote:
weldor2005 wrote:This is looking awesome, I haven't got the machining capabilities, so I ordered my parts and will be cutting the frame and figuring that out shortly. Decided to use some step blocks instead however.
Question, I ordered both the keyed 5/8" shaft and 4" drive wheel with a 5/8" hole that is keyed, and they measure out to be just that, should I press them, or slightly sand the shaft down for a not as tight fit?
I would not press them. They will require replacement . . . Mine slip on and are keyed.
I just called Beaumont and asked them on their take, and they say that it is likely that the 5/8" shaft has a burr on it from being saw cut to length. I never even looked at it, will check tonight.
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
btburn
Post by btburn »
Well, your build inspired me and I went and ordered aBaldor VM3550 3ph 3450rpm motor to start my build. It will take me a while to collect parts but I've gotten some good ideas from your build and others. I'll probably need your help with the VFD from the sound of it.
Dynatorch 4x4 SuperBee, Powermax 65, Quincy QT-54, Snap On MM250SL, Thermal Arc Arcmaster 185, Corel Draw X7 and a messy garage.
Oldsarge
Post by Oldsarge »
6x12 Home Built Table
Hypertherm PowerMax 85
Oldsarge
Post by Oldsarge »
weldor2005
Just happens I've got the parts sitting around and just need to make a frame, haven't been able to conceptualize it very well yet and make a drawing. Ordered the drive shaft as I currently am thinking belt driven, but to leave it open to being a direct drive someday. Using this http://www.harborfreight.com/1-horsepow ... 68288.html to power it, it says it is only 1 HP, but when you take the amps times the volts and divide the ~760 Watts/HP, I come up with 2 HP. This might explain why the reviews people were describing it the way they do..
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Oldsarge
Post by Oldsarge »
CNCCAJUN
Post by CNCCAJUN »
Sarge, nice thing about the grinder you built is all the accessories on the Beaumont website will run on your grinder.
Steve :D
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Oldsarge
Post by Oldsarge »
btburn
Post by btburn »
That KBAC-27D is the one I've been looking at. Where did you order it from? It looks like Amazon has the lowest price of about $380 shipped. it doesn't have the extra switched but switches are cheap.
http://www.amazon.com/KBAC-27D-Black-Dr ... B007YA2YYE
My motor should be here next week and I'll start on my design.
I'd definitely be interested in ordering the wheels. I'm also planning on putting a 10" contact wheel on mine and maybe later a small radius wheel set.
What size drive wheel are you using.
I've ordered the 1 1/2hp 3450rpm motor so I'm thinking 4" maybe 5"
CNCCAJUN
Post by CNCCAJUN »
btburn wrote:That KBAC-27D is the one I've been looking at. Where did you order it from? It looks like Amazon has the lowest price of about $380 shipped. it doesn't have the extra switched but switches are cheap.
Sent you a PM
Dynatorch 4X4 XLS
PowerMAX 85
Oldsarge
Post by Oldsarge »
Oldsarge
Post by Oldsarge »
SeanP
Post by SeanP »
Good to see you back at the grinder there, very impressive, the motor control is great, thanks for the update.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
very nice looking belt sander/grinder looking forward to the finished video.
weldor2005
Sarge,
What is the dimension on the tool arm that slides in and out of the frame. I think you are using the same as a KMG, so that it will fit as well if you ever buy one? Just curious what to design mine around.
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
CNCCAJUN
Post by CNCCAJUN »
The KMG uses a 1 1/2" X 1 1/2" solid in either steel or aluminum.
Price from Beaumont Metal Works (KMG) is $80.00.
If you need any dimensions from a KMG let me know.
I just bought one with several accessories.
Dynatorch 4X4 XLS
PowerMAX 85
Oldsarge
Post by Oldsarge »
plain ol Bill
Post by plain ol Bill »
And another thing ------ Heat is a problem when heavy grinding on parts, especially if you are working with metals already hardened. I keep a bucket of water under the wheel or platen when grinding to dunk parts into to keep them (and my fingers) from getting too hot. The bucket of water under the grinding also helps control dust a lot. A few drops of dawn dish soap in the water lets all the dust settle to the bottom of the water. Never did figure out how to turn the bucket horizontal without the water pouring out though :lol:
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
CNCCAJUN
Post by CNCCAJUN »
plain ol Bill wrote:And another thing ------ Heat is a problem when heavy grinding on parts, especially if you are working with metals already hardened. I keep a bucket of water under the wheel or platen when grinding to dunk parts into to keep them (and my fingers) from getting too hot. The bucket of water under the grinding also helps control dust a lot. A few drops of dawn dish soap in the water lets all the dust settle to the bottom of the water. Never did figure out how to turn the bucket horizontal without the water pouring out though :lol:
Check out Nathan's water cooled/chilled platens . . . .dissipates the heat to "touch comfortable" . . .
You circulate water via a small pump or simply use a domestic water connection . . . if you live in Louisiana that is . .
Dynatorch 4X4 XLS
PowerMAX 85
weldor2005
Steve, Sarge,
Thanks for the input, I will go by some 1.5" and probably build it around that.
Sarge, How much clearance did you allow for the tool arm? the cylinder bushings is good deal, I cant get repeat ability like that myself though.
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Oldsarge
Post by Oldsarge »
I have a question I have looked at these grinders for some time now and one thing I don't agree with.
That is the use of the 1-1/2" solid bar steel for the sliding supports. I think 1-1/2" 1/4" wall tubing would be more the enough and would be much cheaper.
http://www.speedymetals.com/pc-4773-825 ... ubing.aspx
That said they are great grinders and this one is superb.
have fun
Tom
Oldsarge
Post by Oldsarge »
CNCCAJUN
Post by CNCCAJUN »
A lot of people in the knife making groups have tried the square tube route.
Typical complaints are some flexing, irritating resonance, tracking problems & no real cost savings considering lifetime of use.
You can not just look at the overall strength of the tube vs. the solid stock because the solid stock provides a far better mounting point for accessories.
It eliminates a lot of engineering problems when it comes to mounting a 20 lb 12" contact wheel and adjustable work rest.
Some go with aluminum square stock & it too works very well.
The square stock is not used for it's support strength, it is used because it will not twist or deflect in the slightest.
Those that use square tube constantly fight tracking problems during actual use.
You have to realize a 1/4 turn on the tracking knob will take you completely from one side of the wheels to the other.
Think of it this way, just how thick would a piece of 12" X 12" piece of square tube need to be to make a "good anvil".
A piece of square tube thick enough to not flex would weigh almost as much as a piece of solid.
My 2 cents on square tube vs. solid stock based on a year of researching 2X72 belt grinders.
I bought a Beaumont 2 HP variable speed with some accessories.
Dynatorch 4X4 XLS
PowerMAX 85
Oldsarge
Post by Oldsarge »
