2x72 belt grinder build.
Oldsarge
Post by Oldsarge »
6x12 Home Built Table
Hypertherm PowerMax 85
akpilot
Re: 2x72 belt grinder build.
Post by akpilot »
I've been wanting to build one of these for some time....Yours is looking good!!
Oldsarge
Post by Oldsarge »
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
Looking awesome...I am very interested in following this project. Thank for the share.
Torchmate CAD
fergy
Post by fergy »
SeanP
Post by SeanP »
Looking foreward to your next update, thanks for posting, looks nice so far!
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
bigcreek
Post by bigcreek »
Now Mike dont you be letting that thing get in the way of my tube roller! (;
Oldsarge
Post by Oldsarge »
Oldsarge
Post by Oldsarge »
Oldsarge
Post by Oldsarge »
SeanP
Post by SeanP »
Looking really good!
Will you have a large dia wheel on the motor side for grinding as well?
Great project well done.
Edit:
That was a dumb question! seen as it will be going uphill :lol:
Powermax XP45
Table build gallery
Oldsarge
Post by Oldsarge »
HammerDownJustin
Post by HammerDownJustin »
Pretty nice looking belt sander. I hope to try one in my future. Ive always wanted to build my own horizontal bandsaw for metal.
Miller 251 Mig
TAP
Gone
Post by TAP »
Oldsarge
Post by Oldsarge »
TAP
Post by TAP »
Thanks OldSarge, Forgot to tell you how nice that belt sander is, You do excellent work, and I to wish I had time to finish everything, 1/2 done projects all over the shop, I'd like to see more of your projects,,
Better get packing, wifes wondering what I'm doing on the computer. :lol:
Tim
plain ol Bill
Post by plain ol Bill »
After having a 2x72 belt sander for years I don't understand how I ever ran a fab shop without one. I even use it to sharpen pencils anymore.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Oldsarge
Post by Oldsarge »
Kentuckyfarmer
Post by Kentuckyfarmer »
Did the belt sander get pushed to the back of the shop LOL, Sarge. That seemsto happen to me all the time
Mike
Oldsarge
Post by Oldsarge »
btburn
Post by btburn »
I'm thinking about building a grinder for grinding blades.
What motor and speed control are you using? Voltage? 1or 3 phase? Rpm?
Just doing homework right now.
Dynatorch 4x4 SuperBee, Powermax 65, Quincy QT-54, Snap On MM250SL, Thermal Arc Arcmaster 185, Corel Draw X7 and a messy garage.
weldor2005
Post by weldor2005 »
This is looking awesome, I haven't got the machining capabilities, so I ordered my parts and will be cutting the frame and figuring that out shortly. Decided to use some step blocks instead however.
Question, I ordered both the keyed 5/8" shaft and 4" drive wheel with a 5/8" hole that is keyed, and they measure out to be just that, should I press them, or slightly sand the shaft down for a not as tight fit?
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
CNCCAJUN
Post by CNCCAJUN »
For those that are not familiar, this style grinder is considered a knife maker's grinder.
Sarge's grinder is an excellent example of the dozens of configurations out there.
If you check out BladeForums.com or KnifeDogs.com you will find tons of info on this type of grinder.
Use key words - KMG Grinder or 2X72 Grinder.
You could spends a week reading all the info out there about this type of grinder.
Myself I chose to by a already built grinder so I wouldn't spend to much time on a grinder.
I bought Beaumont KMG 2 HP Variable Speed.
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
CNCCAJUN
Post by CNCCAJUN »
weldor2005 wrote:This is looking awesome, I haven't got the machining capabilities, so I ordered my parts and will be cutting the frame and figuring that out shortly. Decided to use some step blocks instead however.
I would not press them. They will require replacement . . . Mine slip on and are keyed.
Dynatorch 4X4 XLS
PowerMAX 85
Oldsarge
Post by Oldsarge »
