Tom has been posting dxf files for awhile now and I am just setting up my table so I decided to try one of his files as my first artsy test cut. This is his Pirate Skull piece. It opened fine in Autocad and Sheetcam and imported to Mach 3 with no issues. I use layers for inside and outside cuts so I can apply different tools to them as per my training at LDR so the only changes I made were to put things on proper layers.
Thanks Tom, Enjoy the fruits of your labor.
Pirate Skull
- tnbndr
Pirate Skull
- Attachments
- Pirate skull.JPG (124.27 KiB) Viewed 1514 times
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Re: Pirate Skull
Everything with the LDR working out ok? Those cuts look good.
- tomloewen
Re: Pirate Skull
Wow Dennis that looks great, thanks for the post.tnbndr wrote:Tom has been posting dxf files for awhile now and I am just setting up my table so I decided to try one of his files as my first artsy test cut. This is his Pirate Skull piece. It opened fine in Autocad and Sheetcam and imported to Mach 3 with no issues. I use layers for inside and outside cuts so I can apply different tools to them as per my training at LDR so the only changes I made were to put things on proper layers.
Now that I see how the end result looks, I see something I forgot to do. That long cutout that runs parallel with the rim of his hat, I was going to join it back up in a couple places to give the piece more straight. I think I'll delete the dxf file and re-post.
Thanks again Dennis, you've made my day!
- captdick
Re: Pirate Skull
Looks like you have got things going great--Talk soon
- tnbndr
Re: Pirate Skull
@762, yes am quite pleased so far. Setup following Dan's training has gone better than expected.Everything with the LDR working out ok? Those cuts look good
Re: Pirate Skull
HI Tom
I looked back through your post a found many files you have contributed but not the pirate skull I hope you re-post as you said here.
Thanks Tom
Thanks Tom
- tomloewen
Re: Pirate Skull
yep, its there now.acourtjester wrote:HI Tom
Thanks Tom
