First try airbrushing!
Finally got the down-draft table working. Took the airbrush out of the box, cleaned it, and using Steel F/X dyes came up with these. Not to bad for a first try... The dyes have an iridescent look to them....can't photo graph the true depth they really give off after you spray 2k clear over them.
- tnbndr
Re: First try airbrushing!
Nice job! Looks like you are on your way.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- CNCCAJUN
Looks great . . .
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
- WyoGreen
I can see I'm going to have to try out steel dyes and an airbrush! Nice work!
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
- tnbndr
Which airbrush did you end up purchasing?
http://www.amazon.com/gp/product/B001TO ... UTF8&psc=1
Not sure if you need THAT particular model, but it seemed to be the most bang for the buck.
Just reminded me...I need more patina stuff from SFX AND some clear....
What pressures were you using, I have not tried on metal yet since my experiment was on glass and was having a terrible time , was great for spider effects
30 psi on the regulator IIRC.
The bird sold for $75 today to the first person that looked at it. Pretty happy about that!
I gave the octo away at $50 cause I didn't want to haul it back home
- CNCCAJUN
Sounds great . . . what area of the country are you in . . .Cracker Red wrote:30 psi on the regulator IIRC.
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
