Clock Hands
- JD770
Clock Hands
Clock Hands Laser cutting on sheet 2 mm redrawn from photos.
- tnbndr
Re: Clock Hands
Very nice!
Do you have a clockworks that will drive those?
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- Larry83301
Re: Clock Hands
Nice clock hands! Do you sell many, if so how much do you charge? Do you put a starter hole for the motor? How long are they from the hole center to the tip of the minute hand? Lots of questions, I know, but I use many hands, most of them from 6" to 11" but some up to 18"
Thanks for showing them.
- JD770
Re: Clock Hands
If someone wants you insert a DXF file so I did only three couples in the Czech Republic the burning of pictures not be make money doing it just as a hobby
