More Plate Marker Art
- Oldsarge
6x12 Home Built Table
Hypertherm PowerMax 85
Re: More Plate Marker Art
you continue to impress, ,great work
I went over to Mikes shop this morning to use his planishing hammer he won from Baileigh in a contest on this forum. I watched him convert this the coloring book page to a file that could be etched and the process was fairly quick and I could not have done it in ten years! He is as good on the computer as he is with his metal work! Also saw a rose he made yesterday and is not quite finished with but if you guys bug him enough he will put up a picture of it I'm sure.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
I like it. Awesome idea!
Home built 3400 x 1400mm (11 and a bit X a bit over 4.5 feet)
Hypertherm Powermax 45
CandCNC Bladerunner IV
Some air dryer off the internet
Another water seperator I found unused on a shelf
Refrigerated air dryer
- tnbndr
Very nice.
I have been experimenting with my scribe also. I'll post in a separate post though.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- Nacs Fab
Looks real good Sarge! I watched the video and noticed the plate you were marking had a slight bow to it. Did this happen during the engraving process? If so, how do you control your depth of cut on the marker if there is some warpage without any type of height control.
G540 with LCTHC by candcnc
all built... by me...
- Metal Storm
yes! how! how do u do this. I have got to get going on this. it seems the more I do the more I learn and the less time I have. and I cant quit the day job doh!Nacs Fab wrote:Looks real good Sarge! I watched the video and noticed the plate you were marking had a slight bow to it. Did this happen during the engraving process? If so, how do you control your depth of cut on the marker if there is some warpage without any type of height control.
- GoingCustom
That came out great! Looking forward to seeing how you finish it!
- East German
Very nice
Regards Peter
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
My guess on depth of cut. The depth is controlled by air pressure. The scriber will ride up (to some degree) over a hump. It is not a fixed height.
Lets see if I'm right.
Precision Plasma 4x8 v-rail
C&CNC dragon cut 620
Auburn, AL
www.facebook.com/decorativemetalworks
Auburn, AL
Just curious, what program did you use to convert this? It turned out great.
