Everything's big in TEXAS
PlasmaDesigns
Post by PlasmaDesigns »
Except this it's a 24" x 24" stainless steel on carbon powder coated.....Anyone ever need a blue bonnet hit me up it took quite some time to draw from scratch......Best regards, John
Redneck
Re: Everything's big in TEXAS
Post by Redneck »
Very nice!
PlasmaDesigns
Thanks Redneck! Your alias describes me to a "T"............ :D It sold for 225.00 delivered from SC................Not too bad but I am hoping to get some good feedback from the customer. Ever need anything just ask, John
tnbndr
Post by tnbndr »
Nice job!
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
RGR
Post by RGR »
What's the method to do an outline of your part.
Cap that they match? I've tried over and over to do a perimeter border around my parts but can't seem to get it right. I like how you did that large Texas back piece and made it a different color. Is there an easier way than hand tracing the part??
muzza
Post by muzza »
RGR wrote:What's the method to do an outline of your part.
If you use CorelDraw it pretty quick and easy using the contour tool, same as this thread but use the outside contour.
http://www.plasmaspider.com/viewtopic.php?f=49&t=14750
Great looking piece too thanks John.
Murray
shinertx
Post by shinertx »
PlasmaDesigns wrote:Except this it's a 24" x 24" stainless steel on carbon powder coated.....Anyone ever need a blue bonnet hit me up it took quite some time to draw from scratch......Best regards, John
nice Texas art work.
Samson 5x10
Designedge software
Hypertherm Powermax 65
Hypertherm powermax 380
Thermodynamics cut master 85
Jet 4' box & pan break
Eastwood Powder coating guns.
PlasmaDesigns
I use Corel draw x3 and x7 There is a handly little contour tool and it is adjustable...If you don't have that just email me the file and I'll do it for you and send it back. It's a 30 sec deal to do it. The studs are welded to the stainless with a stud welder and then they get bolted onto the backplate using nuts as spacers.....You cut the design flipped upside down and you make tiny pin holes on the side that get the studs and fire really high so it doesn't pierce all the way through and bingo you have a mark for the stud welder and it all lines up with the backplate holes.........Fairly simple but takes some practice......Best wishes, John
