Georgia Bulldogs
DXF
Georgia Bulldogs
Post by DXF »
Made this for my Daughter in Atlanta who is an avid fan.
Dave Hanks
little blue choo
Re: Georgia Bulldogs
Post by little blue choo »
Very nice. If you're a G fan. LOL All kidding aside It does look very good. How did you mount them together? It looks like some sort of pop rivet. I have been using 2 sided tape but interested in other ways.
Rick
Rick
Arclight 9600 4x8 table
DXF
Post by DXF »
little blue choo wrote:Very nice. If you're a G fan. LOL All kidding aside It does look very good. How did you mount them together? It looks like some sort of pop rivet. I have been using 2 sided tape but interested in other ways.
Rick
Locate and burn .200" diameter hole in the rear pieces. Drill them out to .218" diameter....my plasma isn't real accurate on holes that small. Locate the rear pieces and use a Sharpie pen with the metal tip to mark the holes from them to locate the nuts on the front piece. Tig tack ( 2 tacks on the points) weld stainless steel 10-32 nuts to the front piece very carefully. Run a 4-flute bottom tap thru them after welding....they will shrink a bit even with tiny tacks. Might be able to glue the nuts on...haven't tried it because I powder coat. Use short 10-32 stainless steel button head screws with washers. Works great and leaves a little gap between the pieces to give them dimension and the heads of the button head screws makes it stand out from the wall a bit.
Dave
little blue choo
Thanks. I might try this method soon.
Rick
kkroger
Post by kkroger »
I just use these, basically mark and such same way but it is a weld nut they even make them with nibs to resistance weld...
I typically just hot tack them with the MIG welder... but TIG would work better.
Craig
Post by Craig »
Turned out great Dave. Craig
Craig Johnson
