Sheriff Badge
- Unvevo
Sheriff Badge
All pieces are mild cold roll 12ga steel. Everything gold I used Copper F/X on and Polished the chrome looking items. Both were then cleared with automotive clear coat. The state seal was powdercoated candy blue. I used rare earth magnets to space everything apart. The heaviest parts I put a dab of ca glue on to keep the magnets from sliding down the super slick clear coat.
Re: Sheriff Badge
Looks very nice it will look better if you could get a straight on shot like it was hanging on the wall.
- Unvevo
Re: Sheriff Badge
I would, I just dont have anywhere to hang it. Its super heavy! I have bolt holes at the tip of the star. It is covered by the circles with magnets attaching them.
- Capstone
Re: Sheriff Badge
so all the layers are held together with magnets? seems a lot less expensive to just use nut spacers and epoxy on all those layers and less apt to come apart if it's bumped/poked/dropped.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
- tnbndr
Re: Sheriff Badge
Nice work! I believe you when you say it is heavy!!!!!
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Re: Sheriff Badge
Nice! I like the layered stuff. But it does look heavy!
Homemade 36X36 table
Can go from Plasma to Router in 10 Minutes
American Modified Chinese Controller
Proma Electronics THC
Cambam and Mach3
Longevity Forcecut 40D
Miller 211 MIG Welder
Cambam and Mach3
Re: Sheriff Badge
Looks great but why so thick? I would of done all the raised letters and some other things out of 16 or 14 gauge
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
- Unvevo
Re: Sheriff Badge
My POS table does not have a THC. I have a hard time cutting anything thin. It warps up and blows out my tips. In 2 months I went through over 20 sets of consumables. It's so much cheaper to use thick metal. I'm new to all of this so I'm slowly learning
- Unvevo
Re: Sheriff Badge
It's something I tried recently and have had really good results with so far. I order them from China so they are pennies on the dollar.Capstone wrote:so all the layers are held together with magnets? seems a lot less expensive to just use nut spacers and epoxy on all those layers and less apt to come apart if it's bumped/poked/dropped.
Re: Sheriff Badge
I ran for 2 years without height control. Cut mostly 14g and some 16g. No issues here really.Unvevo wrote:My POS table does not have a THC. I have a hard time cutting anything thin. It warps up and blows out my tips. In 2 months I went through over 20 sets of consumables. It's so much cheaper to use thick metal. I'm new to all of this so I'm slowly learning
Re: Sheriff Badge
very nice. piece of work.
any ideas on where i can get Texas State Seal?
