Light switch Covers
- Dennis
Light switch Covers
Light switch plate covers.
- Attachments
- user28424_pic11842_1233846610.jpg (18.08 KiB) Viewed 5900 times
- user28424_pic11846_1233846650.jpg (12.23 KiB) Viewed 5900 times
Re: Light switch Covers
Very cool work, Dennis!Dennis wrote:Light switch plate covers.
Pam @ Opie's Heavy Metal, LLC
Hey Dennis
Very nice. I made up a file for the Decor wall covers so after I cut them and make sure that they will fit I will post the pictures of them. I want to make sure that the layout is correct.
Rod S in AZ
Very nice work, gives the rooms a nice look.
- AnotherDano
Here are a couple of Garys girlz. Haven't found the right customer yet. Seems the wives aren't too thrilled with it.
But, they DO like the horses;
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
That gives me an idea for one they might like even less...AnotherDano wrote:the wives aren't too thrilled with it
hello
nice work is it possible to have the dxf file thank you.
- Dennis
I would put one of those girls on the horse, that way the wife and husband both would be happy.
- Dennis
Is the image just held on by the pressure applied from the switch plate..AnotherDano wrote:Here are a couple of Garys girlz. Haven't found the right customer yet. Seems the wives aren't too thrilled with it.
- AnotherDano
That's right, Dennis.Dennis wrote:Is the image just held on by the pressure applied from the switch plate..AnotherDano wrote:Here are a couple of Garys girlz. Haven't found the right customer yet. Seems the wives aren't too thrilled with it.
The design allows the plate to be universal, for use with switch or outlet.
Dano Roberts
- AnotherDano
SignTorch Vector Art wrote:That gives me an idea for one they might like even less...AnotherDano wrote:the wives aren't too thrilled with it
Go for it, Gary!
Your Trucker Girls are really very versatile;
Dano Roberts
- AnotherDano
It's a Signtorch file. Talk to Gary about that.lestubes wrote:hello
Dano Roberts
- AnotherDano
Another reason I chose that open style is to prevent problems like this, where the switch/outlet was installed poorly. Most of us could fix this easily, but never the customer we sell it to.
Those plastic covers are concave for a reason.
Dano Roberts
Dano, what inside dimension do you use for these?
- tnbndr
99% are like that. So when I see the original post where they cut out the switch opening I wonder if the entire thing sits off the wall slightly. Hard to tell from the pic.Another reason I chose that open style is to prevent problems like this, where the switch/outlet was installed poorly
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
I think most will sit away from the wall slightly, but it is very hard to tell if you give it a nice border. No one has complained yet from buying them from me, so I don't think it is a huge deal. I would just put in the website post, that if your hole and switch is real bad and uneven, they may not look the best, but to me any kind of metal art switchplate cover is better then plastic.tnbndr wrote:99% are like that. So when I see the original post where they cut out the switch opening I wonder if the entire thing sits off the wall slightly. Hard to tell from the pic.Another reason I chose that open style is to prevent problems like this, where the switch/outlet was installed poorly
Any ideas on a cost/time effective way to radius the edges? Essentially, duplicate the standoff of the plastic covers?
