So a couple of improvements to my table setup.
1. Moved all of my electronics onto the rolling cart I built earlier. This is in prep for my move to a real shop where I won't have a wall close enough to the table to keep the CandCNC AIO setup or the PC/Monitor. As a bonus, I am using a ELO Touch Screen. It's not 100% reliable at the moment, but in testing I was able to get it to work quite well with MACH3.
2. I finally got the magnetic breakaway torch mount finished, minus the micro-switch e-stop, which I'll be finishing up this week hopefully with help from the posts that others have already put up that have done it before on this forum
Table Build ~ Cart and Magnetic Torch 2.0
- Capstone
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Re: Table Build ~ Cart and Magnetic Torch 2.0
Nice work thinking about a magnetic attachment myself.
- Capstone
I wasn't considering a magnetic breakaway torch until this happened. Doh!
Phil
CNC Metal Design
JD Squared 4x8
CNC Metal Design
JD Squared 4x8
- Capstone
I've added some custom panels to hang small useful tools to have nearby and to add a bit of branding flair.Capstone wrote:So a couple of improvements to my table setup.
It's one sheet of 16Ga with little tabs cut out to hang stuff
Phil
CNC Metal Design
JD Squared 4x8
CNC Metal Design
JD Squared 4x8
