Air compressor silencer
Just acquired this heavy monster. I am planning on placing it in a corner and walling off 2 sides with sound deadening material panels. Not sure how I'll vent it yet. Anyone made panels that work at muffling the sound? Is it better to place the compressor on rubber mount bushings? Thanks
Dave Hanks
Dave Hanks
- CNCCAJUN
Re: Air compressor silencer
Have not done mine yet, but after much research I have found that the majority of noise generated by a compressor is at the INTAKE ! ! ! I have a new QUINCY 7.5 that will get your attention inside a metal building.
They make ($150.00_) or you could make a silencer. It is simply a muffler. Supposably reduces the noise considerably.
As to sound dampening material, OWEN "The Pink Panther" makes a sound deadening material that is not that expensive and can be bought at a home center that carries their products.
If you really need quite, do both insulation and a silencer . . .
http://homedepot.owenscorning.com/acoustic-performance/
Rubber pads, studs in slab to keep it from walking. Use nuts and washers, but DO NOT TIGHTEN, LEAVE 1/8" to 1/4" gap. The nuts and washers are ONLY in case something or someone runs into it so it want topple over.
First instinct is to tighten, my QUINCY dealer has a 5hp in their shop they show people so they can see what happens when you secure a compressor to the floor. It tears it's self apart.
The pads will reduce transfer of vibration to floor. Compressor vibration transmitted to the floor could begin showing up in your cut quality. No, I did not believe it either, but it does.
Hope that helps . . .
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Yes on the rubber. If you can just put it on a rubber mat before you bolt it down. Tractor supply has some nice ones for $20 for a 4'x4'x3/8" piece. Helps reduce the vibration and sound transfer through the slab.
Foam wallboard works ok for sound, I have had good luck also with the tiles that are used for a drop ceiling, they soak up quite a bit of sound but are not really durable for stuff banging into them etc. Outside would be better, if you could rig a lean to off the side of the shop so the roof would keep the rain off, then it would be a whole lot quieter. I worked at a place where the compressor was inside, if it's what you have to do then it is what it is, but man it was miserable. If it has to go inside, you are going to want some earmuffs when you are doing much cutting.
Shane
Shane
I silenced mine very effectively 5 years ago. Moved it outside under a roof overhang. It runs at 20 below zero occasionally....starts a little hard but have not had any issues. Much nicer inside now!
Jim Colt
Jim Colt
I left mine on the pallet it was shipped on and put it in a back room.
Allen
Allen
- CNCCAJUN
Mine is inside. I live in a subdivision & I know my neighbors would not appreciate it outside.
I went with a 7.5 HP Quincy wit an 80 gallon tank.
A little overkill, but my thinking is I will recover faster & with 80 gallons @ 175 PSI I may last a little long between runs.
Know soon if my thinking is right. Will put an intake silencer on & walls if necessary.
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
My Quincy is pretty quiet. It's a 5hp though. If you had it running with the garage closed and went outside, I'd be surprised if it made any more noise than a car going down the street.
- CNCCAJUN
I agree . . . when my roll-up door is closed you can barely tell if it is running 20' away . . .Metriccar wrote:My Quincy is pretty quiet. It's a 5hp though. If you had it running with the garage closed and went outside, I'd be surprised if it made any more noise than a car going down the street.
I'm going to try to borrow a real decibel meter to do a before and after with the silencer . . .
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
I mounted my Quincy on Hockey Pucks... Worked great
- CNCCAJUN
uuuuuuuuuuuuuuuuuuuuuuuum! Where would you get a Hockey Puck in Louisiana . . .dewser wrote:I mounted my Quincy on Hockey Pucks... Worked great
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
- 4.5 Star Member
The tank might amplify the sound a bit. My tank is separate and I buried it underground, definitely helps give more floor space It's also great for condensing the moisture out of the air.
I mounted the skid on inflatable tyres to help with vibration transmission. Google for silencing compressors, generators, etc and you should find a few enclosure designs that allow for air circulation too.
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
- steelfx
I had a 7.5 h.p. IR in my last shop 3 yrs. back. Really noisy until I ran the Air Intake outside. It was only an 18" run of 3/4" Galv. Iron Pipe & the Air Intake Housing & Filter were under an overhang. That cut the noise by at least 50%. Auto-Drain on the bottom of the tank, set at 15 Second duration every 30 minutes. That sound is something I could never get used to. Buggered me a little every time it spit!
Bill
Bill
I have 5hp IR 60 gallon vertical that is in it's own 5x5' room behind the shop with the rotary phase converter. I've never bolted it down and it does not walk around. You cannot hear it run through the CMU walls. Ventilation is must.
Victor Simonis
Grey Forest MetalCraft
Helotes, TX 78023
210-872-2622
Helotes, TX 78023
210-872-2622
- BrianMick
ever hear of ebay?CNCCAJUN wrote:uuuuuuuuuuuuuuuuuuuuuuuum! Where would you get a Hockey Puck in Louisiana . . .dewser wrote:I mounted my Quincy on Hockey Pucks... Worked great
www.midwayiron.com
www.midwayiron.com
Thanks everyone for your input. I'm wondering if you could just enclose the motor and pump if it were vented right. And also place the compressor on rubber mounts.
Dave
Dave
- steelfx
If you're close to a farm & ranch store, get a stall mat or horse-trailer mat (same thing).DXF wrote:Thanks everyone for your input. I'm wondering if you could just enclose the motor and pump if it were vented right. And also place the compressor on rubber mounts.
Dave
They're built tough & not very expensive. You want to isolate, not mount...meaning: don't run any bolts into the concrete with too much torque. The compressor needs to "float", not be too tight with the floor or it will shake itself to death.
bw
- CNCCAJUN
Please listen to the part of NOT BOLTING THE COMPRESSOR FIRMLY TO THE SLAB. Place on rubber something. Use stud in concrete to keep it from acting like an old electric football game. The nut is only to incase it tries to topple over. I left 3/16" of play. I have in this order from slab up . . . a vibration pad (rubber), compressor leg, another rubber washer, metal washer, then the nylon insert nut.steelfx wrote:If you're close to a farm & ranch store, get a stall mat or horse-trailer mat (same thing).DXF wrote:Thanks everyone for your input. I'm wondering if you could just enclose the motor and pump if it were vented right. And also place the compressor on rubber mounts.
Dave
bw
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
- _Ogre
i have stairs headed up to the hay loft in my barn. i enclosed the stairs to keep heat in and hung a plywood door. my compressor room gets a little warm in the summer. but i can converse or listen to music without adjusting the volume.
an ogre smiley how cool!
If you have a good one that doesnt vibrate across the room,
just leave it on the palate.
done it for 30 years.
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
HI SORRY I AM CONFUSED DO YOU RAP THE ISULASION ARROUND THE COMPESSOR PUMP (PISTON) WIL IT NOT OVER HEAT
Build a box around the pump and motor with insulation. Vent it so it stays cool.mossie wrote:HI SORRY I AM CONFUSED DO YOU RAP THE ISULASION ARROUND THE COMPESSOR PUMP (PISTON) WIL IT NOT OVER HEAT
Dave Hanks
- _Ogre
even a box needs to be plenty big to prevent the compressor from overheating and then vent it well to the outside
the more heat you keep in your tank the more moisture you will have in your lines
- 4.5 Star Member
A small box will be perfectly OK so long as the ventilation is adequate. The only time a big box would make any difference is if the ventilation was inadequate, but then a big box would only DELAY overheating on the inside due to the extra volume of airspace. If the temperature can continue rising in any size box there's not enough airflow._Ogre wrote:even a box needs to be plenty big to prevent the compressor from overheating and then vent it well to the outside
The key is ventilating the hot air as as fast as (or faster) than what it is generated.
Keith.
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
I have a Campbell and hausfield comp and I just put a small piece of electrical tap across the intake aboujt 1/2 way covering the hole ..it reduce the intake noise pretty good and it was cheap
