Down draft grinding table
rons
Post by rons »
Does anyone use one and can you share some info about it.
I getting tired of the shop always being covered from the grinding crap and breathing it this is next on my to do list so buy, build, plans looking for some help and I am sure everyone here needs one.
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
Lathe, BP, 1" x 12" Cosan Miter Saw,
tnbndr
Re: Down draft grinding table
Post by tnbndr »
I was going to build one years ago, but it never got done and I don't have room for one now.
Just have a sheet metal shop build you a transition from top size of table, 36x30 down to around 12x12 and put a slide out drawer at 12x12 to remove grindings, etc. Part way up the transition tap a hole , add a collar for 6 or 8 inch pipe and route to exhaust fan. Table top was going to be heavy gauge flat expanded metal. Hope that helps or stirs up some design ideas.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
whiskeymike
Post by whiskeymike »
I bought a Delta 4x4 down draft sanding table at a garage sale last week for $100. Great deal and it works awesome. Normally sells new for $450. Problem is that it's for wood working. I'm debating if I should reconfigure for metal. The inside throat is a paper filter which would obviously not be good. So what I might do is move the vacuum out from the bottom and build a cyclone trap for the metal dust. The other idea is build a cyclone in the middle prior to the filter, but I need to protype some stuff up to see if it would fit.
The other thing I'm doing is building an air filter from a squirrel fan and motor. I'm hopeful that takes care of the fine dust that seems to cover everything everywhere.
Marty
Post by Marty »
I just use a broom, dustpan, and once in a while, wet mop
Problem solved
Ignition Metal Art Design
Give a man a fish and you have taught him where to come for a fish; Teach him to use Google and the Search Engine on Plasma Spider and he will be able to learn more than you could ever teach him yourself
whiskeymike
Here's the manual to the table I got. Shows how it's made/structured. Thought you might want to see. http://www.deltamachineryparts.com/docu ... 900512.pdf
gamble
Post by gamble »
Grizzly sells one for metal working but it's nearly $2k. Maybe by next year I will get one. Would be great for painting and powder coating too
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
Post by jimcolt »
I'm currently building two downdraft hand cutting stations to demo the new Hypertherm Powermax45 XP at the upcoming Fabtech show. They could easily be adapted for grinding with a different design up on the top. These use Torit brand welding fume filters. Here are a couple of pics early in the build stage.... Jim Colt Hypertherm
whiskeymike
What fan is that Jim?
david47julie
Post by david47julie »
That is great design verry well thought out, thanks for your time and photo your input is always valued and apreciated thanks again
Post by jimcolt »
It is a 14", 1/3 HP fan with totally enclosed motor. I built the fan housing.....as this style improves the static pressure so it will pull well through the filters even after they are partially clogged. If you have the ability to roll 16 ga steel....this is a low cost way to make a powerful fan. The TEFC motor is a must as well. Jim Colt Hypertherm The pic is of two 16" fans of similar design that I built for two cnc machine downdrafts last year.
whiskeymike wrote:What fan is that Jim?
rons
Post by rons »
Jim,
Thank You very much do you have a source for the fans and filters
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
gamble
Post by gamble »
Anyone else have any input? I'm thinking of ordering it
Someone did tell me not to mix them for steel and aluminum because it can ignite and explode. Apparently aluminum dust is combustable. ?
steel 35
Post by steel 35 »
Here is one of mine.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
gamble
Post by gamble »
What cfm does it pull and how well does it work
steel 35
Post by steel 35 »
1038 CFM I have not sealed up the 2" perimeter gap so it wont pull enough at the farthest end.
If things fall through the holes :o
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
gamble
Post by gamble »
How well does it work for grinding off dross on steel with fumes and dust?
steel 35
Post by steel 35 »
I am happy with it, Its another project i need to Finnish but its always covered with another project or 3.
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
gamble
Post by gamble »
ok well i decided to try it out and ordered the grizzly downdraft table. Let you know how it does.
gamble
Post by gamble »
Got the table, So far I only have about 10 minutes with it.
It's pretty quiet and with the air pulling down and the rubber grommets the 19"x19" piece of metal didn't move at all while grinding it
The side walls aren't very tall, the downside is when the metal hits it they bounce off with a lot of force and got behind my full mask. I need to layer the side walls with something fire resistant to absorb the impact
The filters are 16x25x1 and 16x25x2 and both are paper of course. So I thought about replacing them with 1 of each of these
https://www.amazon.com/16x25x2-15-63x24 ... al_qh_dp_t
https://www.amazon.com/16x25x1-15-63x24 ... esh+filter
do you guys think having both of those would be good enough? Some people are saying I need a spark arrestor and a spark filter etc etc
gamble
Post by gamble »
how can i test the CFM once I put new filters in? Want to see if I lose anything
steel 35
Post by steel 35 »
Manometer?
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
