Cutting Galvanized Sheet
Econdron
Post by Econdron »
Is it the same settings as if cutting standard raw steel? I have a job coming up cutting 12ga galvanized steel. I'm not sure if the sheet is hot dipped or electroplated. I know it makes a difference when welding which method is used, but does it make a difference when plasma cutting?
Gamelord
4.5 Star Member
4.5 Star Member
Re: Cutting Galvanized Sheet
Post by Gamelord »
Be sure to have plenty of ventilation, galvanized can be brutal to your health.
Torchmate CAD
Post by jimcolt »
Cut specs are the same as for steel. Jim Hypertherm
