When i run a job at the end of the cut the z axis does not retract up to the rapid clearance it just remains at cut height and goes to x/y zero. This only happens on long runs. Any ideas?
I have installed a powermax 45 XP with CPC but with hand torch modified for remote firing. I have wired my own cpc interface cable with a connector I bought from ebay, i have wired everything in the cpc except pin 13 which is for ground ( i am not sure where to ground it to)
I am using the minithc torch heigh control which has worked well with my old powermax 800 which did not have a CPC port but was wired to use raw arc voltage etc.
I now have the minthc wired to the CPC of the new 45 XP and i am having this problem at the end of the cut.
What may be the possible causes for this? When i do a dry run it works well but when i turn on the plasma and enable the thc this is where it goes crazy at the end of the cut. I am using mach3 ans sheetcam. Thanks in advance
Help with end of cut problem
D.I.Y 4x4 CNC Plasma Table with water tray
60 Gal. A/C + D.I.Y Aftercooler + Water/Oil seperator + Desicant air dryer
45XP (CPC with hand torch)
MiniTHC
UCCNC + Sheetcam + Inkscape / AutoCAD
MiniTHC
Re: Help with end of cut problem
What CNC machine, what height control, what software? Jim Colt Hypertherm
My machine is a DIY using stepper motors, the height control is the MiniTHC http://minithc.com/ (miniTHC universal kit) I am using sheetcam and mach3.jimcolt wrote:What CNC machine, what height control, what software? Jim Colt Hypertherm
I have attached a video in a zipped folder (sorry about the quality of the vid had to compress it so i can upload here)
MiniTHC
MiniTHC
I watched the video and it sounded like the Z motor stalled and that is why it did not raise up.
You may try reducing the Z velocity and acceleration a little (mach motor tune).
that sound is actually the plasma cutter, is that normal? also you can see how the flame dies down, its not an instant flame outacourtjester wrote:I watched the video and it sounded like the Z motor stalled and that is why it did not raise up.
The system runs fine when I do a dry run with the plasma off, the problem only happens when I do a long cut, short cuts are fine.
The last system was working well with the older powermax 800 but I had to open the unit to access the raw arc voltages, get the arc ok signal via a sensor (from the miniTHC kit) and modify the hand torch but with this new 45 xp everthing is connected to the CPC port, this is the only thing I did different.
Could the problem be from mach3?
MiniTHC
MiniTHC
I am only going on the grunt sound which happens just as the Z would be moving up, which it does not.
To Change the Z acceleration and velocity number lower is a quick check and easily return to the original numbers.
These are in the Mach 3 Motor tune section under the config tab.
While on the main screen in Mach you can move the Z up and down by pressing the page up then page down keys. Do this as fast as you can you may hear that grunt noise.
There will be other in a short time giving their ideas, that is what is so helpful about this site
thanks i will check my z axis velocity
MiniTHC
MiniTHC
Also if you are using the MACH3 THC logic there is a setting for THC Rate (or there should be) that sets the velocity under THC. The lift at the end of a cut is a distance and if you are losing steps DURING a cut it will think its higher than it really is and just sit there (or worse go down instead of up). Stop it at the end and see what the Z DRO says. If its not where the torch actually is it last lost position.
Thanks guys i decided to install a copper ground rod to the table and this seems to have helped so far, did two jobs and everything went well.
MiniTHC
MiniTHC
