sheetcam problem ?
sheetcam problem ?
I got some file from free dxf great product but when i load into sheetcam and do the setup (type of metal ga Etc and layers when I get done it put lines in the file that were not there before not sure what the problem is I'm new to all of this .If you could help a newie out that would be great
Re: sheetcam problem ?
Are you attaching lead-in and lead out line. The blue line in SheetCam are rapids and are showing the torch moving between parts. If the new lines are attached where you have a yellow S and a number these are lead in.
If not will you attach a screen shot sowing the lines you are talking about
Sometime I can just kick myself I had the leadin and leadout set to none when I change them the lines went away I feel like a dumb %#% I over think things to much Thanks for your time this site is the best
Happy to help
- tnbndr
Welcome to the club!!I feel like a dumb %#% I over think things to much
been there. many a time
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
