my best seller welcome sign
This site is awesome thanks for all the help and the files. Heres one i made its my best seller.
instead of jamie and sue it says welcome in what ever font i used a disney font from dafont.com
hope you guys can use it.
Re: my best seller welcome sign
dont know how to get the file to show......sry....maybe someone else can post the file.
Last edited by b.ackerman@live.ca on Sun Jan 13, 2013 5:30 pm, edited 1 time in total.
Thanks for sharing.
- Gamelord
- 4.5 Star Member
Here's the picture. Just export it as a .JPG or .BMP and upload that image along with the DFX. You would upload two images total.
*file deleted because it is no longer needed*
thanks for sharing
thank you!
- Laser Chicks
Super Cute! Thanks for the file share
LASER CHICKS
LASERMANN CUTS LTD
# 2, 6718 Golden West Avenue
Red Deer, Alberta
T4P 1A8
http://www.lasermanncuts.com
LASERMANN CUTS LTD
Red Deer, Alberta
T4P 1A8
- billyeagley
Thanks for sharing!
PlasmaCAM 5x10 (Samson) - DesignEdge - Hypertherm Powermax 65
- Larry83301
Took the liberty of changing your file, hope you don't mind.
- Zippo
thanks for posting... cute
- MetalheadRK
This is super cute. Thank you for sharing!
4x4 PlasmaCam
Hypertherm 45
Eastwood 175 MIG welder
Hypertherm 45
Thank you for sharing.
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
Sheetcam, Mach 3
- Buzzard Gut
- pony
I'm still very new at this, having only created one of my own original pieces.
I like this one a lot, but when I opened it, it was a lot of separate pieces (the image was the same, but it wasn't continuous).
I spent 30 mins joining all the lines and then simplifying them. I also changed the font (personal preference).
Can an 'expert' take a quick peek at this and tell me if its OK. In my possibly naive thought process, I thought this one would be easier to cut. The file size dropped by 1/6, which, as long as the image looks comparable, is good, right?
The original welcome image had lots of segments and showed 4586 objects.
By using the "join curves" tool in Corel X5 set at 1.0mm this automatically reduced the same image to 60 objects.
The "O" has duplicate lines and is not bridged properly, fixing this reduces it to 51 objects.
So with what you have done you have 56 objects so yes the file size will be considerably smaller.
Yours is 56 objects as oposed to 51 because you still have an extra segment(object) in the dogs mouth,1 extra in the cats nose, 1 where the two ears meet and 2 extra in the cats right eye.
I'd say fix those few and it will be perfect, hope that helps.
Murray
Murray
- pony
Thanks Murray,
So, are you saying the original image benefits from being reduce to the 51 objects, or would this make little difference to the cut (other than file size). I guess I'm asking why it had all those extra objects in the first place.
Also, I dont have Corel (I design on a Mac and X5 is not available for Mac). Did Corel join all those curves in a single click? It took me a long time to select all the elements in Illustrator and join them. If its automatic in Corel I may need to buy a copy to use on my Windows PC.
I'm not sure how to remove those extra objects to pointed out, as it breaks the path. I need to explore Illustrator more to figure out how to join the broken paths back together, I think.
Thanks for taking a look at this.
Still learning the basics here...
muzza wrote:The original welcome image had lots of segments and showed 4586 objects.
Murray
I was always under the impression that a smaller file is better.pony wrote:Thanks Murray,
Some systems will handle lots of segments better than others. When there are a lot of segments quite often it wants to cut it that way and is continually piercing and cutting each bit, by joining them it becomes a long smooth cut resulting in a better job and less wear.
Yes, that is basically a one click operation (4 really) in Corel X5 and X6, took all of a few seconds to do, just select the drawing, select join curves, set the parameters (I use 1.0mm) and applypony wrote: Also, I dont have Corel (I design on a Mac and X5 is not available for Mac). Did Corel join all those curves in a single click? It took me a long time to select all the elements in Illustrator and join them. If its automatic in Corel I may need to buy a copy to use on my Windows PC.
In Corel it joined those ones too so I just compared the two end results to see where the extra segments were. Not sure will Illustrator but assume you would join as you did the otherspony wrote:I'm not sure how to remove those extra objects to pointed out, as it breaks the path. I need to explore Illustrator more to figure out how to join the broken paths back together, I think.
Me too and I wouldn't be where I'm at without the help I have had from here so thanks again to everyone who has helped.pony wrote:Still learning the basics here...
Murray
- pony
Thank you for sharing this one. Wife says it is 'super cute'
Hi nice file and very cute being your best seller what are you selling it for I'm just starting and really having trouble with setting prices or what I should be selling them for. What finish are you putting on them are you painting or powder coating them. thanks Don
- pony
I've not sold any of this style yet. I cut a couple of similar ones (welcome signs, but personalized with their surname instead of 'welcome') at 20 inches wide. I just started to sell items. I initially asked $49, both buyers said it was too low and that they thought they were worth closer to $99
So, I asked, and got, $79 a piece +tax. I finished them with a rattle can of matt BBQ grill paint. I plan to ask the same for these too.
Don't undersell yourself! You can always drop the price, it is harder to increase it later, especially if the new buyer is a referral from a past sale
