marlin breaching (aka fish)
I figured it was time for me to share. I have downloaded enough. Anyway this one I traced and have cut once. It cuts great fine cut, but don't go smaller than 12" to 15" in height. good luck
Re: marlin breaching (aka fish)
Nice, Thanks for sharing.
Danny
Danny
Plasmacam 4x4
Hypertherm 65
Acad, Corel Draw
South Carolina
Hypertherm 65
Acad, Corel Draw
South Carolina
- ctorres3120
thanks very good file
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Hypertherm PowerMax 1250
http://www.facebook.com/ctorresp?ref=tn_tnmn
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
thanks for sharing
- hdfaster
Very nice, Thanks much!
thanks much!
Thank you
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
Having a lot of trouble cleaning this one up!. The outline and part of the face are selectable with corel draw no problem. Join nodes and reduce. But the inside/detals of the fish I can't seem to do anything with.
I had to open it in inkscape first....opening in CD7 it wasn't workable (for me).
Try this one...Cracker Red wrote:Having a lot of trouble cleaning this one up!. The outline and part of the face are selectable with corel draw no problem. Join nodes and reduce. But the inside/detals of the fish I can't seem to do anything with.
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
I downloaded the file then reduced size to 20" x 20". I had to modify it to cut at the smaller size.
cut out of 16 gauge cold rolled carbon steel then used steel dye on it then clear coated it.
rh
rh
Thank you !!
Cleaned that one up a long time ago in corel 4 and it cut fine in a smaller version.. Forget the size will have to ck.. Jason your cleaned version looks great as well.. Thanks
1250 hypertherm
CandCnC electronics
CandCnC electronics
Thank You
- SeanP
Thanks for the share, been wanting something to experiment with colour mixed in with clearcote for a while.
18'' wide
18'' wide
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
- Buzzard Gut
Wow, that turned out really nice Sean
The older I get, The better it was!
I cut this out for an aunt address sign. 2 layers epoxyed together 14' x 12'
- Larry83301
That looks real nice. Thanks for posting the picture.
