A little something to get you into the Holiday Spirit
M & N Steel CNC
Post by M & N Steel CNC »
3 Christmas ornaments I cut today, and dyed with STEEL-FX DYE.
Christmas ornaments and angel group.dxf
PlasmaRoute CNC 4 x 4
Corel Draw X5
SheetCam
Baileigh 12 gauge 40 inch box brake
M & N Steel CNC
Re: A little something to get you into the Holiday Spirit
Here's a pic of the Angel Ornament with Steel-FX yellow dye.
Corel Draw X5
SheetCam
abmagrum
Post by abmagrum »
Nice,
Thanks for posting
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
J2m_fab
Post by J2m_fab »
Thanks alot!
aweston
Post by aweston »
Thanks these are great. How are you applying the dye from steel FX? I tried the brown but it did not look as good as yours, it dried instantly and tended to be streaky.
bwgsmith
Post by bwgsmith »
Thanks for sharing.
M & N Steel CNC
aweston wrote:Thanks these are great. How are you applying the dye from steel FX? I tried the brown but it did not look as good as yours, it dried instantly and tended to be streaky.
For these I am using a small paint brush, appying the dye and following the stroke until the brush completly runs out of dye, I make sure my brush is not saturated, wipe it on the bottle both sides first so it will not be so runny. It takes very little dye to cover this, in most cases cannot even tell it has dye on it, one you shoot it with clear the color pops out.
I tried another ornament in orange, and the application was not as nice as the yellow. I have also airbrushed bigger pieces but my airbrush system is not the best and it over coats using way too much dye.
Corel Draw X5
SheetCam
34chev
Post by 34chev »
Very nice.
Buzzard Gut
Post by Buzzard Gut »
Cool, Thanks
The older I get, The better it was!
Zippo
Post by Zippo »
Thanks for posting.
Shaunlb
Post by Shaunlb »
Thank You!
james.davis
Post by james.davis »
They look great.
Jim
david jordan
Post by david jordan »
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
