Chimenea
thissideup
Chimenea
Post by thissideup »
The file is almost ready to post, but I need your help. I want to put a gusset under the tray table. I'd like it to look like the wood work on old victorian front porches. Has anyone got a file like that?
762frmafr
Re: Chimenea
Post by 762frmafr »
http://all-silhouettes.com/ has some scroll work vectors that might be what you are looking for.
thissideup
Re: Chimenea
here it is, decided not to use any gussets, shelf holds up fine. keep in mind the chimney is more for effect than function, it will still let some smoke out the front, but trust me, this things throws heat like a mother. I used 4'' .125 tubing for the chimney.
thissideup
Re: Chimenea
one more,
MetalTorcher
Re: Chimenea
Post by MetalTorcher »
Looks great like the rest of your work. I'm always jealous of your welds.
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
cmercertx
Re: Chimenea
Post by cmercertx »
Lots of free vector art on craftsmanspace.com, mostly scrollwork.
RGR
Re: Chimenea
Post by RGR »
I like it...Looks like a fun project...2 questions...In the cad file, Are the small square pieces with holes the gussets for the tray bottom? and what gauge are you using to cut this from?
thissideup
Re: Chimenea
RGR wrote:I like it...Looks like a fun project...2 questions...In the cad file, Are the small square pieces with holes the gussets for the tray bottom? and what gauge are you using to cut this from?
They are tabs for the bottom of the feet incase you want to add caster wheels. I used 3/16. when you're putting the front and the sides together, the seams are on the side, not the front or rear. If you put it together any other way, you'll see the floor doesn't fit.
shiner2001
Re: Chimenea
Post by shiner2001 »
Love this project, looks like a great one to put together. Many thanks for the share.
I was wondering about part of the drawing on the DXF that appears to be a line that's out of place. It's the roof line of the rear panel. I attached a screen shot of it open so you can see what I am talking about.
Derek
Precision Plasma LD 4x8
CandCNC BladeRunner EtherCut Mark IV
HT PM 45
thissideup
Re: Chimenea
shiner2001 wrote:Love this project, looks like a great one to put together. Many thanks for the share.
b
not sure what happened there, but both front and rear have the same outline, you can simply just cut the front out twice without the door if you can't get the file to open correctly.
agmechman73
Re: Chimenea
Post by agmechman73 »
thanks for sharing great project for my students to complete and have something to show off and be able to tell others what they did in class :D
Hartofsteel
Re: Chimenea
Post by Hartofsteel »
Thank you for sharing.
mbowers
Re: Chimenea
Post by mbowers »
Your files and creations are always first rate. I made a few of your fire pits last year for Christmas presents and they were all huge hits. Thanks again!
My mind not only wanders, it sometimes leaves completely.
The world is full of people smarter than me...
