needing help turning into dxf file help-Finger Bracker
im needing help making this pdf file into a dxf file any help would be very appreciated....thanks
- Gamelord
- 4.5 Star Member
Re: needing help turning into dxf file helppppp
Here's a quick clean up and trace. You will need to check dimensions on the DXF to make sure they are correct. If it is off you should just need to scale it to be right. It most likely will need detailed cleanup before cutting.
Torchmate CAD
Torchmate CAD
Re: needing help turning into dxf file help-Finger Bracker
Gamelord thanks so very much if there is anything I can every help you with just lmk I finally got my cad system up and going again u def saved my a,, thanks again and anything u need lmk we also do 2-d and 3-d sand cast and anything on a table or waterjet.
- CNCCAJUN
What is it?
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
- SeanP
I need the practice drawing as well, try this.
one with .5'' hole and the other .484 for reaming?
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
Looks like a finger for a bow press.
