Pirate Skull
- tomloewen
Pirate Skull
Hey you guys, please let me know if there are any issues with this file . . . I got a lot of help from Murray but still got growing pains
Tom
I made a little revision to the original file. I joined up the long cutout that runs parallel with the rim of his hat in a couple places just to give the piece more straight.
Tom
Tom
Tom
Re: Pirate Skull
Looks good Tom. All joined, good nodes just one little bit, the nose is floating and will drop out, just needs to be connected to the main part.
Murray
Murray
- tomloewen
Re: Pirate Skull
oh CRAp I should have caught that. I'll delete it and repost. Talk about a rookie mistakemuzza wrote:Looks good Tom. All joined, good nodes just one little bit, the nose is floating and will drop out, just needs to be connected to the main part.
Murray
- tomloewen
Re: Pirate Skull
tomloewen wrote:oh CRAp I should have caught that. I'll delete it and repost. Talk about a rookie mistakemuzza wrote:Looks good Tom. All joined, good nodes just one little bit, the nose is floating and will drop out, just needs to be connected to the main part.
Murray
ok . . . I attached the nose
- 4.5 Star Member
Re: Pirate Skull
Hi Tom,
I brought it into Coreldraw and all looked good. However when I brought it into Sheetcam as an SVG, one of the cut paths were funny. I come across this periodically where it looks perfect in Coreldraw but I get issues in Sheetcam.
Anyway, in Coreldraw made some changes to the offending bit, re-exported and brought into Sheetcam again and all cut paths generated good.
Here's my Coreldraw file and the SVG file IF you need them. Correction - the SVG won't upload, this forum software is funny like that, only likes certain file types. Have you got Coreldraw ?
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
- SeanP
Re: Pirate Skull
Nice work, it's not easy drawing something like that.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
- tomloewen
Re: Pirate Skull
Hi Keith, yep, I got a demo of CorelDraw that I just started using. I was using Draftsight but the other guys like Larry, Jason and Murray noted some major problems with my files . . . turns out DraftSight does not do well with CNC; it's main purpose I think, is to draw and print. So Murray got me going in a straighter line with CorelDraw, (no pun intended)beefy wrote:Hi Tom,
Keith.
And actually I'm not a cutter, I'm just some guy who likes drawing this stuff up; I really enjoy it. But I don't really feel my files have served their purpose until they're put to use. (and yes . . . this is another hint!) If you other guys cut this stuff out, please post a photo. I've been married for 35 years and seldom get laid, this is the only excitement I have . . . post them!
Tom
- tomloewen
Re: Pirate Skull
Thanks Sean, actually this one wasn't too bad, the other one I posted, (Highwaymen Cash Nelson) was a bit of a challenge, off hand I think it took six hoursSeanP wrote:Nice work, it's not easy drawing something like that.
Tom
- tnbndr
Re: Pirate Skull
Tom:
You've been very generous and hinting(begging) for someone to cut out your art. Check out the post in the other forum of this Pirate skull cut out.
http://www.plasmaspider.com/viewtopic.php?f=12&t=13907
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Re: Pirate Skull
Thanks Tom the file is safe on my disc
You seem to like to do wall art type things thanks again for sharing.
- Zippo
Re: Pirate Skull
Thanks for posting.
Re: Pirate Skull
Tom, you have come a long way in a very short time!! Awesome work.
If and when I get my shop back up and running I will cut a few for ya, but still gonna be a while here unfortunately. Day job pays alot better at this time..
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
- tomloewen
Re: Pirate Skull
I sure appreciate your comments and I wish you the best with that, thanks.Largemouthlou wrote:Tom, you have come a long way in a very short time!! Awesome work.
Tom
Re: Pirate Skull
awesome file cheers
Re: Pirate Skull
Fantastic!
Re: Pirate Skull
Looks awesome!
Dynatorch 4x4 SuperBee, Powermax 65, Quincy QT-54, Snap On MM250SL, Thermal Arc Arcmaster 185, Corel Draw X7 and a messy garage.
