Converting PDF to DXF.
Can anyone tell me the best way to convert PDF to DXF ? Or can anyone be so kind as to convert this for me ?? I am not the most computer literate person in the world ..
Re: Converting PDF to DXF.
copy it as a screen shot into jpeg format and convert in Inkscape as talked about here
http://www.plasmaspider.com/viewtopic.php?f=6&t=14050
Thank you so much for taking the time to do that for me.. I read that attachment & its all foreign to me Maybe this winter I will actually force myself to figure this converting stuff out more, so I can design more of my own pieces instead of buying dxf files.. thanks again,, have a great weeekend
- kb3gun
Not sure this will help much, but I imported the pdf in to Illustrator then exported in to dxf. There was a lot of data in the pdf but you should be able to clean it up. I had to zip it to upload due to the file size.
Hope this helps.
Hope this helps.
-Smitty
Torchmate 4X4 Growth Series w/AVHC
Hypertherm PM45 w/ Machine Torch
Miller Syncrowave 210 TIG
Open it up in Coreldraw. It is already a vector file
What version of coreldraw?
