help with dxf file-Hand water pump
welding
Post by welding »
Hand water Pump.dxf
Hand water Pump.dxf
Hand water Pump.dxf
I am trying to get this water pump attached to the inside of a square but I am not having any luck. Can anyone help me with this. I need to be able to cut this so the pump stays inside he square. I would like the square to touch on the top and bottom and on the handle. Thanks Andy
Just John
Re: help with dxf file
Post by Just John »
Hi,
Not Exactly sure if this is what you meant. I am new myself so let me know if this works for you,
WyoGreen
Post by WyoGreen »
I took Just Johns file one step further by adding a rectangle outside, hopefully making it cut the way you want.
Hand water Pump Revised2.dxf
Router
Laser
welding
Re: help with dxf file-Hand water pump
Post by welding »
Thank you. Both pictures look perfect I am not sure what one I will use yet. Thank you again Andy
