Floor drain grate
Floor drain grate
On the pizzazz scale this one barely rates above a resting hearbeat, but I thought I'd share it anyway. It's sized at 13.5" diameter but you can scale it to any size you want. I cut it out of 1/4" steel.
http://www.plasmaspider.com/images/floo ... -grill.jpg [/img]
[img]You currently do not have access to download this file.
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
Re: Floor drain grate
Another one on the same scale or lower.hot air register cut out of 3/16 plate.
Thank you for the files.
Gary
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
Sheetcam, Mach 3
- Zippo
Thanks for posting.
Greetly apreciated
Thanks for sharing
Thanks for sharing
