Fillet weld guages
n2weldn
Fillet weld guages
Post by n2weldn »
Hope someone can use these. I drew these up for my students because they never seem to remember to return my set. I don't burn the sizes in these as they are drawn. Would probably look great if someone had a scribe feature for there table.
fillet weld guage.dxf
fillet weld guage.pcm
otisa2007
Re: Fillet weld guages
Post by otisa2007 »
nice thanks for the share
Largemouthlou
Post by Largemouthlou »
Thanks :D
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
n2weldn
Post by n2weldn »
Thanks for adding the image. Is there a post or instructions somewhere that shows how to upload an image?
Rem300wm
Post by Rem300wm »
Hello to All
n2weld to post files or pics,just open the reply post and there are 2 tabs one is options the other one is upload attachment,click on that tab and there You will get a option to browse for the file or pic,select it and second click on "Add the file" and this will add the file,after that just click submit and You are done.Hope this helps.
Rem.
sbest1
Post by sbest1 »
If you're a member, just click on the dxf name at the top or bottom of the picture.
Zippo
Post by Zippo »
Thanks for posting.
Maineiac
Post by Maineiac »
Thanks - great file!
admin
Site Admin
Post by admin »
n2weldn wrote:Thanks for adding the image. Is there a post or instructions somewhere that shows how to upload an image?
You can upload an image the same way you upload a dxf file. Just click on "upload attachment" tab below the text box you type your post into and "Browse" for the image you wish to upload. Click on "Add the file" and your done.
Laser Chicks
Post by Laser Chicks »
Sweet, Thank you for sharing.
I just had a request to cut a set these and thought to look here before I did all the measuring and drafting going from the samples he brought in. Saves me a bunch of time and I really appreciate the share :D
LASER CHICKS
LASERMANN CUTS LTD
# 2, 6718 Golden West Avenue
Red Deer, Alberta
T4P 1A8
http://www.lasermanncuts.com
troyandersonwelding
Post by troyandersonwelding »
i was woundering if anyone had the next bigger set of fillet gauges 1" 1/8 and higher thanks
