Elk Key Holder
Elk Key Holder
I finish drill the outside 2 holes to 1/4 and the other holes are 5/32
Re: Elk Key Holder
Here is the dxf.
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
Re: Elk Key Holder
I am new to this site, still trying to figure it out. Thank you sir
Travis Harshbarger
Plasmacam DHC
Plasmacam DHC
Re: Elk Key Holder
Thanks for sharing.
- Larry83301
Re: Elk Key Holder
Thanks for the file, the elk looks great!
- hdfaster
Re: Elk Key Holder
Great file thanks for sharing it!
- billyeagley
- Zippo
Re: Elk Key Holder
Thanks for posting.
Re: Elk Key Holder
Been trying to get my settings right on this for 2 days. Last cut at 160 speed at 40amps with powermax 85 running a fine cut 45amp tip with shield. Wondering what setting you guys are using. thank you and awesome file.
- wilber
Re: Elk Key Holder
are you trying to cut it out of 11 gauge? if so speed is about right. For 16 gauge i cut around 300imp at 45amps. I don't have my specs in front of me but i normal use that to get started and dial in from there.
*** DynaTorch Super B 4x8 with a Hypertherm Powermax 65****
Re: Elk Key Holder
yes 16g but it seems the faster I go, I get burn back? but I also think I have wrong shield too
Re: Elk Key Holder
Very nice, thank you!
Re: Elk Key Holder
Nice thank you.
Re: Elk Key Holder
Awesome - Thanks!!
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Hyperthem PM65
Re: Elk Key Holder
Looks awesome, I like that you didn't use just a plain rectangle for the bar
Re: Elk Key Holder
Thank You
Re: Elk Key Holder
what table r u running ,i cut some 16 ga last night an i had to slow it down to 120 or 130 @40 amps it seams like cold rolled an carbon steel cut differentquadboy wrote:yes 16g but it seems the faster I go, I get burn back? but I also think I have wrong shield too
