Pit Bull hanger
Pit Bull hanger
First balance it on an 8 penny nail. Draw a straight vertical line to mark the center of balance. Curvy lines work too. Some times you have to remove part of the sawtooth hanger. Bend the spacers the same height as the sawtooth hanger and spot weld on. Make the spacers parallel with the sawtooth and centered where you spot weld them on and you can't see them when it's hanging.
Dave Hanks
Dave Hanks
- CNCCAJUN
Re: Pit Bull hanger
Dave, are you using a tong type spot welder or just making small TIG welds?
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Re: Pit Bull hanger
I'm using a spot welder.CNCCAJUN wrote:Dave, are you using a tong type spot welder or just making small TIG welds?
Dave
- CNCCAJUN
Re: Pit Bull hanger
With the pointed tongs?DXF wrote:I'm using a spot welder.CNCCAJUN wrote:Dave, are you using a tong type spot welder or just making small TIG welds?
Dave
Does it leave a mark on the front?
Which spot welder did you go with?
Thanks, Steve
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
Re: Pit Bull hanger
very cool. what are those clamps or things you are spot welding on called?
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
Re: Pit Bull hanger
I used the hand operated one. It does some times leave a small mark because the top tong was bent when it fell off my table and my trigger finger isn't real accurate. I tried to straighten the tong. Needs more work and adjusted. When I get the big one going it will spot weld perfect. They're both Millers and 220 volt. The round pieces spot welded on are spacers.
Re: Pit Bull hanger
Wow you make some cool stuff!
Where can I get those spacers at? home depot?
- CNCCAJUN
Re: Pit Bull hanger
You cut them, Dave posted the file . . .see sawtooth file above . .gamble wrote:Wow you make some cool stuff!
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
Re: Pit Bull hanger
lol doh! Sometimes it's hard for me to remember I can make a lot of this stuff.CNCCAJUN wrote:You cut them, Dave posted the file . . .see sawtooth file above . .gamble wrote:Wow you make some cool stuff!
edit: i've been ending a piece of tig filler wire of 1/8 or 3/32 into a U shape and tig welding it on as a hook. i like this option better
- CNCCAJUN
Re: Pit Bull hanger
OK Dave, you are costing me money . . .
Now I'm shopping for a spot welder . . .another Miller coming my way . . .
I have been trying to figure a hanging method that I could do easily . . .
Based on your system it appears a spot welder would be lot quicker than a MIG or TIG . . .
Also your stand off method really adds to the overall appearance . .
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
Re: Pit Bull hanger
Those small things gotta be hard to hold in place prior to clamping the arms down, no?
Re: Pit Bull hanger
Thanks, Great idea!gamble wrote:lol doh! Sometimes it's hard for me to remember I can make a lot of this stuff.CNCCAJUN wrote:You cut them, Dave posted the file . . .see sawtooth file above . .gamble wrote:Wow you make some cool stuff!
Dave
- tnbndr
Re: Pit Bull hanger
I use the same methods as DXF but instead of spot welding I plug weld them from the from or back and grind the front side smooth. Takes but minutes.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- kgc1031
Re: Pit Bull hanger
I like the pit bull cut out. Can you share the dxf file?
