Inappropriate roasting sticks.
Whipped these up today, made of stainless steel, rods are 3/16 plate is 20 gauge, though I might go thicker next time, edges get pretty sharp. Handles are dead willow that was debarked with a knife then burned then varnished. I have only one rule for anyone that downloads my files. That you enjoy them! and if you feel so obliged to alter them, please share!
check us out ! www.thefirepitfactory.com www.polartracks.com
Re: Inappropriate roasting sticks.
Hey very nice take on the cooking stick just a note the DXF posted in not the same as your pic shows in case there was a mistake but thanks for sharing ..... G
Greg From Storiesnsteel
oh? what's different? I work in PCM format then export,gcw8 wrote:Hey very nice take on the cooking stick just a note the DXF posted in not the same as your pic shows in case there was a mistake but thanks for sharing ..... G
Oh wow, I just opened it in Corel, pretty crazy. Ill post up the PCM file and maybe somebody else will have better luck exporting it as dxf?thissideup wrote:oh? what's different? I work in PCM format then export,gcw8 wrote:Hey very nice take on the cooking stick just a note the DXF posted in not the same as your pic shows in case there was a mistake but thanks for sharing ..... G
here's the PCM, somebody else might have better luck exporting it as a dxf.
- 1MORECUT
Here's the dxf from the pcm file
1morecut
1morecut
Looks awesome thank you guys I am wo0rking on a few different versions of roasters I will share when finished
I have seen these before !! Never had the file !!! Thanks alot!!!!
Bob
Bob
thank you for sharing!
- david jordan
very nice
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
