Sign for Mema's Garden
OakRidgeFarms
Post by OakRidgeFarms »
A sign I have drawn up, but late at night now, so will have to test it on the machine tomorrow.
It is a .plt file, as that is what works best for the Tracker CNC system.
Enjoy
Tracker CNC Nitro 4x8 Table
Powermax 85
SigmaNest
Corel Draw x7
Hobart Handler Wire Feed
Miller Bobcat 250 Welder Generator
http://www.facebook.com/ORFarms
Largemouthlou
Re: Sign for Mema's Garden
Post by Largemouthlou »
Nice!! Love the tomatoes :D !!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
storiesnsteel
Post by storiesnsteel »
yes when you fire up the tracker you can import the plt file and burn away I do see an issue with the file that might go bad for you is the holes look like they might just burn your frame apart so I would remove the holes and just drill them after I have run into this myself ... good luck and nice file
Greg From Storiesnsteel
OakRidgeFarms
Happened exactly like you said, the holes ate up the frame....too bad I saw this AFTER I cut it! lol....
Adjusted the file, reposted.... and this time cut fine. Paint is drying as we speak.... Will post finished pics later.
Also exported to a dfx file for those that use them....
Powermax 85
SigmaNest
Corel Draw x7
ironhorse
Post by ironhorse »
I really liked you file. I changed it for a customer, I hope you don't mind.
