I need help converting this to a dxf. This is for a friend of mine that is special needs and wanted to give it for her ribbons
Help With angel wings
- Rem300wm
Re: Help With angel wings
Hello To All
Well the picture is no good, too small,so I draw this for You.At least will get You started.
Hope that It helps.
Rem.
Hope that It helps.
Rem.
Thanks for your help
- Rem300wm
Hello to All
No Prob, glad to help.
Rem.
Rem.
Looks good Rem. Just curious, what program did you use to convert? I use DesignEdge with my PlasmaCam and the picture works just fine.
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
PlasmaCam DHC2
MADE IN USA
- Rem300wm
Hello to All
KD i did not convert the image,it was too small and not a good trace came out of it,so i went and made it from scratch in Corel X7.I think it was faster this way to be honest.
Rem.
Rem.
- Larry83301
When you cut this file make sure you check the lettering, a couple of letters are missing!
- Rem300wm
Hello to All
Larry ,You are very correct Sr.,sorry for not using my glasses,well got the problems corrected from the file and re uploaded it.
Like always check before you cut .
Rem.
Rem.
