I've been wanting to make a scroll bender for a while now, but I've always been stumped on how to make the scroll properly.... Found an old blacksmith trick for figuring out a "Perfect Scroll" and took that info into Corel & it worked. I don't know if anything like this has been posted before so here's another one if so.
Anyway, I don't have a lot of time these days to get to drawing the center & breaking the scroll into sections, so I thought I'd throw this out there to see what the collective can do with it!
Happy Scrolling!
Oldsarge
A perfect scroll
- Oldsarge
A perfect scroll
6x12 Home Built Table
Hypertherm PowerMax 85
- steel 35
Re: A perfect scroll
Similar to what your after using pin's, something I started long ago and lost track of it.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
As far as the layout of the spiral goes, it's just 3 half circles each with diameters half that of the previous (mine is 6", 3", and 1.5" diameters for example)
I strayed across this the other day. There are two common types - Archimedean spirals and Logarithmic spirals. There was a site that would generate a DXF for either type, but I can't find it now.
Archimedean:
https://www.desmos.com/calculator/4j41rzdkxb
Logarithmic:
http://mathworld.wolfram.com/LogarithmicSpiral.html
Archimedean:
Logarithmic:
- Oldsarge
Played around with this a little more today... This what I came up with... Thinking to drill & pin each piece to a 3/4" thick plate that my vise is attached to. Any ideas & improvements welcomed!
Oldsarge
Oldsarge
You may think about a way to rotate the jig instead of the material. Never know what you might need to put a scroll on, and having 15 feet of 1/8" by 1" swinging 360 degrees around the shop would surely prove to be unwieldy.Oldsarge wrote:Played around with this a little more today... This what I came up with... Thinking to drill & pin each piece to a 3/4" thick plate that my vise is attached to. Any ideas & improvements welcomed!
Oldsarge
- Larry83301
Did you see the scroll attachment on this bender that you can make? Check it out in the video starting at about 8 1/2 min in. The whole thing is an Instructable.
http://www.plasmaspider.com/viewtopic.php?f=6&t=22310
Instructions on the whole bender with scroll attachment are at - -
http://www.instructables.com/id/Homemad ... dium=email
- Oldsarge
jason.jason.p wrote:You may think about a way to rotate the jig instead of the material. Never know what you might need to put a scroll on, and having 15 feet of 1/8" by 1" swinging 360 degrees around the shop would surely prove to be unwieldy.Oldsarge wrote:Played around with this a little more today... This what I came up with... Thinking to drill & pin each piece to a 3/4" thick plate that my vise is attached to. Any ideas & improvements welcomed!
Oldsarge
Actually for some time now I've been thinking about fabricating a ratcheting head that I can mount various bending jigs to that I could ratchet around as I bend instead of moving the material... Now that I recently picked up a mill that I'm trying to make heads or tails of I might try to do something along those lines!
