My First Submisson
My First Submisson
Had a customer request a "Flame Cat" design....this is what I came up with and figured I'd share. This was programmed to cut on a Waterjet just so you know
-Logan
-Logan
- plasmajoe
Re: My First Submisson
Thank you Logan, very nice file. Thanks for the heads up about the waterjet.
- BrianMick
Wow logan, my eyes go buggy just trying to follow all the flames to see if it willl cut good. great job
www.midwayiron.com
www.midwayiron.com
- parrotlady
Excellent work! Thank you!
April
April
- hdfaster
Great job combining the lion with the flames.
THANKS!
THANKS!
Here is a picture of one cut...The picture you see is of the initial program...I edited the spots i didn't think looked right and it should provide a better part than the one you see here.
-Logan
-Logan
Do you mind reposting the final dxf file....I would love to cut that one out for my shop...Thanks in advance, great looking work.
The file posted is the revised copy. The picture I posted of the part was the first program, the file is the updated .dxf
-Logan
-Logan
- Chopper John
Nice drawing Logan. What type of waterjet do you run, I have an Omax 55100.
Chopper John
Mad City Cycles, Inc.
I run a gantry style Flow machine. With a 10' x 20' foot table, hyperjet 100 pump setup running at 93,000 psi.
I'll try and post some pictures later
-Logan
-Logan
- Larry83301
I?m jealous! Which I had a 10' by 20' machine. Mine machine only cuts 27" by 40", and only wood for now ( no coolant).
LOL! Its actually one of the largest on the East Coast. Ive cut everything from 1/4" Neoprene Rubber to 6" thick Stainless Steel.
-Logan
-Logan
Logan,
I envy you! I have a plasmacam DHC with HT 600.
Tim
Red Robin Creatives
Tim
Red Robin Creatives
- Chopper John
Just a curiosity question. Did you use conversion software on this, or trace it ? I noticed the extremly low amount of elements in this drawing, and as you know a waterjet wants to go to every end point. This would cut very quick with all those smooth arcs.
Chopper John
Nice Observation...
Some elements of the face were traced, the rest was hand drawn by me. Its completely original
-Logan
-Logan
