Garden Sundial DXF FIle
spooky
Re: Garden Sundial
Post by spooky »
extremely nice work carn't wait to cut and build one of these up.
Metriccar
Re: Garden Sundial
Post by Metriccar »
That link that muzza provided tells what angle to make the gnomon and where to position the numbers, but how do you know how long to make the gnomon? I think I will build one of these.
SCHIDTHEAD
Re: Garden Sundial
Post by SCHIDTHEAD »
Metriccar wrote:That link that muzza provided tells what angle to make the gnomon and where to position the numbers, but how do you know how long to make the gnomon? I think I will build one of these.
The gnomon is in the cut file; no need to make it.
"Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one."--Thomas Paine 1776
Fordgal
Re: Garden Sundial
Post by Fordgal »
That is beautiful. Thanks.
retiredcpo
Re: Garden Sundial
Post by retiredcpo »
Really nice file
thanks for sharing it.
This will look outstanding in my back yard
kirstipic
Re: Garden Sundial DXF FIle
Post by kirstipic »
That is beautiful!
Metriccar
Post by Metriccar »
I really want to make one of these, but sort of confused by this statement:
***ALSO--this dial is set at 38.85? N as with the gnomon, so if you want it to keep accurate time for your location, the dial angles and the gnomon have to be set to your latitude.
How do I go about doing this? Like let's say I want it to be 31? N.
SCHIDTHEAD
Metriccar wrote:I really want to make one of these, but sort of confused by this statement:
Yes, your angles of the dial numbers, relative to 180 degrees, and the angle of the gnomon / are set to your latitude.
Go to: http://www.anycalculator.com/horizontalsundial.htm and enter your latitude in the calculator and it will give you your angles for the hours, and, depending on where you live, deflection of true north as well.
As for the gnomon, if your latitude is 31* N, your gnomon's angle will be 31* to be perpendicular to the earth's axis.
Hopefully this helps, if not p.m me and I can set up your correct sundial to your zip code and really get your dial dialed in.
Steevo
Patrick Waite
Post by Patrick Waite »
seem that I am having trouble fixing this file. When I down load the file all the line are broken. Ive tryed to fix the file with Corel x5 but my computer keeps jamming. Is there some other DFX file out there that some would like to share
Patrick
SCHIDTHEAD
when I find time I will load it into X6 and see what it does...I dont use CorelDraw for my dxf designing, more for graphic art; my dxf designs are all done in CAD
kbenz
Post by kbenz »
Thanks for sharing, that is sweet
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
SCHIDTHEAD
Yaller very wecome...
Patrick Waite
Thank you
Patrick
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
Schidthead,
I can't believe my luck.
I did a sign for a friend of mine for his house. He said he's also interested in a sundial. Well that left me scratching my head a bit.
I haven't looked at this section of the forum for about 3 weeks and what's the first thing I see when I decide to look again.
Awesome, thanks for your great generosity in sharing such a wonderful piece.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
pecos
Post by pecos »
very nice work, I am new to the forum congratulate greetings
youngr
Post by youngr »
Wow, This is amazing. I am new to this site and really appreciate your work and generosity in supplying the dxf file of the sundial. My wife loves the look of it and this will be my first big project on my plasmacam. Thanks again.
Richard
bogger44
Post by bogger44 »
awesome, Thanks
Jeff M
Post by Jeff M »
Man what a beautiful piece of work. THANKS !!!
hdled
Post by hdled »
Thank you
randallwelds
Post by randallwelds »
WOW! NICE!
mmrsam
Post by mmrsam »
super job
gs123
Post by gs123 »
thanks for the file.
i found a site that has software that you can download and set your location and create all sort's of
sundials. (free) that's always nice.its called shadows.
here it is,i hope this helps someone.
http://www.shadowspro.com/en/index.html
john inslag
Post by john inslag »
Thank you for this file!!
Klinzmann Fabrication LLC
Post by Klinzmann Fabrication LLC »
Awesome piece Thanks :D
rdj357
Post by rdj357 »
Beautiful work, thanks for sharing!!
