motor locks up on rapid speed
bogger44
Post by bogger44 »
I have a dyna cnc table, (lucky i got one with cand cnc electronics) 5x10' 200in/lb motors one on the y axis
It has been good but latley the y axis locks up when it rapids to the next cut it locks and loses steps and starts cutting in the wrong place.
i changes the velocity setting for the motor from 40 to about 20 now seems ok now why would that change? thanks
Re: motor locks up on rapid speed
Post by jimcolt »
Best bet is to go to CandCNC's support forum and post this question. They are at www.candcnc.net
I am guessing that you are exceeeding the torque capability of the stepper motors.....could be something in the movement of the machine binding up.
bogger44 wrote:I have a dyna cnc table, (lucky i got one with cand cnc electronics) 5x10' 200in/lb motors one on the y axis
bogger44
Post by bogger44 »
it runs fine it's just when it goes from cutting speed to rapid it locks and looses steps it has been running the original settings from day one. but now i was wondering that the motors are getting old maybe that's the prob.
grindergary
Post by grindergary »
I was having the same issues with my table. I was told to turn down the acceleration and velocity a little bit and it seems to have worked so far. I am going to do a complete tear down soon and will be checking everything. I will then start to increase the velocity and acceleration to where it was before.
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
B Holmes
Post by B Holmes »
It sounds like some mechanical binding. I have had this issue before as well. Stepper motors lose torque as rpm increases, therefore having less power to drive through a tight spot at rapid speeds as compared to cutting speeds. Hope this makes sense.
5 x 10 Air bladder water table
Precision plasma HDB gantry
CandCnC 620-4 Bladerunner
Feather touch ohmic plate sensing
Hypertherm Powermax 65
2015 Autocad lt
Mach 3
Central California
