Start Shaphon SH-2012AH/QG
teddgt
Post by teddgt »
I recently purchased a machine from China and I'm having problems with the controller. I'm trying to figure out the factory settings for the controler, specifically for the speed, system, plasma and control tabs, or if anyone could share the settings they have metric or imperial. I changed my settings without keeping record of the factory settings and now the torch is stock in the middle of the table, with out been able to move -X or -Y from that point where it gets stock... It can only move +X or +Y from that point. It seems as if the machine Is set up to not move past that point for -X and -Y and I'm not sure how to change that.
Please Help.
TST
Re: Start Shaphon SH-2012AH/QG
Post by TST »
Hi, did you try to restore factory parameter setting?
TST
Post by TST »
Hi, did you try to restore the factory parameter setting?
1. Key-in GG3 after the screen is on.
2. Choose (Parameter) in the dialog box.
TST
Post by TST »
Try the steps below to restore factory parameter setting.
1. Key-in GG3 in the main menu.
2. Choose PARAMETER in the dialog box.
universe
Post by universe »
Hello,
I have the same issue of the OP, and I followed your steps with GG3, but the keyboard is stuck at this menu, I could see File format and Parameter but I can't select or do anything,
Thanks in advance for any hint
