Bull Bear market file
I am looking for the Bull and Bear Market "symbol". It is a longhorn bull and a bear fighting. Anyone have any leads on something like this?
Re: Bull Bear market file
I did a google search and found several that could be cut ready fairly quick. I do not have one to share that is cut ready maybe you could do a quick trace. I searched for " bull / bear market image" and clicked on the images tab.
Shane
Shane
This is what I am looking for. I didn't find anything like that that would be easily traceable.
- CNCCAJUN
It's close to the current market. . . but probably not what you are looking for . . .
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
- primaldesigns
Here's one that I whipped up. Maybe it will be a starting point for you. Maybe you can clean it up some of the lines but should be ready to cut as is.
Thank you. Not quite what I was looking for, but I might be able to make it work.primaldesigns wrote:Here's one that I whipped up. Maybe it will be a starting point for you. Maybe you can clean it up some of the lines but should be ready to cut as is.
See if this helps
- CNCCAJUN
When I saw this JPG I thought of it as a lighter side to the market, but I'm thinking it may make a good file.CNCCAJUN wrote:It's close to the current market. . . but probably not what you are looking for . . .
Now if I can get my "zip" file creating skills going I'll see if I can make a file of it.
Is it a bad choice for converting . . ?
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
