I just got a contract to build a few different style brackets for a client and was wondering is there a function on the plasmaCAM software to wich you can draw one item then have the whole 4x4 sheet filled with the item... versus using the copy method.? I can fit about 100 of these pieces on a 4x4 sheet was just wondering if there's an easier/faster way other then the copy button...
Thank you
Adam
PlasmCAM DHC2 NESTING Question..
- elkriverfab
Re: plasmCAM DHC2 question..
Adam,
You can use the nesting feature to do what you are wanting.
It will nest all parts in order to get the most out of your sheet.(great feature).
Just keep in mind it will put them very close together and depending on the thickness of material, just keep an eye out for warping on the sheet.
thanks very much.. but where the heck is this nesting feature located? I had heard of it before but do not see it anywhere in the software.?
Thanks again
Thanks again
- elkriverfab
Re: PlasmCAM DHC2 NESTING Question..
Adam,
I will have to go through my manual today to get the exact procedures to nest them.
I used it a few times a couple of years ago but not a lot since.
From what I can remember it was real easy, just haven't used the feature in a while.
I will look at the manual today and get back to you.
thank you that will be very helpful since i dont know where my manual is..
- BrianMick
It is called array.....highlight item....go to drawtab...select array...choose rectangular....select # horizontal and vertical copies......click ok......left click item....drag to upper right until piecees are spaced appropriatly......click again and poof........ done ....word to the wise convert to cut paths first
www.midwayiron.com
www.midwayiron.com
thanks Brian this is gonna speed a couple things up for me..!
- BrianMick
