battle worn betsy ross flag
i was playing around and took a couple flags and put them together to come up with this what you guys think I have plasma cam file n don't no how to switch to dxf but if some one on here can ill send it to them to repost
Re: battle worn betsy ross flag
I thought I had picture with it but I guess not I cant figure it out
need some help figuring out how to add attachments to these
[image][/image]
- Larry83301
If you want to post a picture or a file just follow these four steps.
# 1 - - Click on the Attachments tab just below this window.
# 2 - - Select the Add Files tab and continue to the folder where your file is saved.
# 3 - - Select the file you want to post.
# 4 - - After you see the bar with your files name and info come up, just place your curser in the message window where you want the file to be and select the place inline tab that is in front of your files name. Not sure why, but as you select files they show up in the opposite order that you selected them in. Just be sure which file you want where in your post.
Hope this helps.
Hope this helps.
here it goes
I not sure why but before I didn't have the place in line option but got it now thanks for the help
- Larry83301
If you are not sure what the post look like you can use the PREVIEW tab in the middle right below the text box. Then you can scroll up and down and check out the whole post before posting it for ALL to see.
nice work thanks for posting
here is the plasmacam file
How do you get that color red? Is that patina? How are you guys finishing these? Do you take the time to tape and mask off?Teelssteel wrote:here it goes
I use the Duplicolor paint which I order from JEGS. FX Steel also sells a dye, of which I have never tried personally. But I hear it works great also.dunnmfg wrote:How do you get that color red? Is that patina? How are you guys finishing these? Do you take the time to tape and mask off?Teelssteel wrote:here it goes
- modelaratrod
Could someone please convert and post the dxf?
5x10 Torchmate 2 w/AVHC
Hypertherm PM85 w/ machine & hand torch.
the color i used on this flag is the patinas from fx steel great stuff easy to use and i tape of the bare steel stripes so the patina does not get on it they also sell dyes for color that i just got and tried and they also work great
the flag was a PCM cut paths so there is a lot of cleanup needed to get rid of all the lead ins.
HERE IT IS CLEANED UP
Thanks for the files and the clean up too.
Wow! This is another great piece! Thanks for sharing!
thanks for converting to a dxf for me and thanks guys just wanted to try some thing new
Thank you!
u all do great work thanks to all
