Fidget Spinners??
Vanquish
Fidget Spinners??
Post by Vanquish »
Hello guys. New to site . Love all you guys do. My 8 year old son wants to make some fidget spinners. Does anyone have a DXF files or can someone make a couple. Thanks in advance. Thanks Craig
harrymorley
Re: Fidget Spinners??
Post by harrymorley »
whats a fidget spinner?
Vanquish
Post by Vanquish »
These are handheld toys kids are playing with. They have small skateboard bearings in them. They hold in hand and spin.
hemichargersrt8
Post by hemichargersrt8 »
These seem popular, I don't get it, but....
They seem to use 22 mm bearings, but I would use whatever size you can find cheap, resize the holes to match the bearing outside diameter and epoxy the bearings in place. Use material thickness to match bearing thickness.
spinner 1.DXF
spinner 4.DXF
spinner 3.DXF
spinner 2.DXF
Vanquish
Post by Vanquish »
WOW. Thanks so much. My son will be so Happy. Hemi I sent you a message.
Metal teacher
Post by Metal teacher »
thanks
motoguy
Post by motoguy »
My son brought one of those home last week. I played with it a while, too. ;) Didn't know they were called "fidget spinners". The designs above look neat...thanks! I think these would be better suited to a 3d printer, though, vs plasma. My son's plastic one can spin mighty fast...I hate to think what it could do to a digit, if it's made of 3/16" material...
Capstone
Post by Capstone »
These "fidget spinners" are a phenomenon sorta like the hackey-sacks when I was a kid. The basic idea is that there are a bunch of people who have OCD/ADD tendencies and this "fidgeting" helps calm a portion of their brain to enable better concentration on the task at hand. What has grown from it is an ever increasing amount of precision and speed through the use of ceramic space-age bearings and highly precise milling of rare metals. I actually met a couple of guys that produced a fidget that costs $700 each, and they are pre-sold out already of over 200 of them, so obviously there's a market. I agree that plasma-cut metal will not unfortunately be part of this craze. 3D printing, which I also do, will, but even that has limitations. It's the people with milling machines that will ultimately reap the most profit.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
rdj357
Post by rdj357 »
Many thanks for sharing the files! I have a laser coming that I plan to customize and cut these from acrylic to sell!
STEEL3470
Post by STEEL3470 »
ok i have been trying to find acrylic... any suggestions on the best place to get it?
rdj357
Post by rdj357 »
Check out Laserbits.com and Inventables.com
I don't have my laser here yet but i have both of those bookmarked as they have been recommended on several forums.
STEEL3470 wrote:ok i have been trying to find acrylic... any suggestions on the best place to get it?
I have used Tap Plastics several times, worked out OK. :D
https://www.tapplastics.com/
Metal teacher
thanks, work good with acrlic and co2 laser
Vanquish
Post by Vanquish »
I cut 3 out of 3/16 Steel. Worked great. Waiting on bearings now.
bigworm36
Post by bigworm36 »
Post some picks once you get the bearings I would like to see how they turned out. I assume you have to drill out the bearing holes so they are more precise?
Arclight 5x5 table
Delta 3 CandCNC controller
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
STEEL3470
Post by STEEL3470 »
bearings is the biggest issue allot of suppliers are running out, im 3 weeks out on my bulk order of bearings,
i cut a few fidgets out of acrylic yesterday and they turned out great just going to press the bearings in and done. im using a laser though.
STEEL3470
Post by STEEL3470 »
file turned out great thanks
STEEL3470
Post by STEEL3470 »
here is the pic
hemichargersrt8
Nice to see people post pics. I always wonder if people only download the files that people take the time to create.
Vanquish
Post by Vanquish »
Looks great. Here are mine. Waiting for bearings now. Thanks Hemi.
Vanquish
Post by Vanquish »
Here we go
hemichargersrt8
Spin away Vanquish!
seajinx
Post by seajinx »
Thanks hemichargetsrt8, grandson was wanting one of these. great files.
Vanquish
Post by Vanquish »
I'm having problems with bearing. I first drill a 22mm then we t to 55/64. 22mm to big 55/64 to tight. What are you guys doing. I'm using 3/16 metal. Might have to use a different material. Thanks guys.
Paint Chip
Post by Paint Chip »
Heat the bodies, freeze the bearings? If it's only a few thou seems like they should slide in. Much more than that might make the bearings bind.
