Nice Motorcyle with lots of detail
- FreeDXF.com
Hello Everyone,
Wow, it has been a very long time since I have shared anything on this wonderful site. Here is a design that is probably one the more detailed and challenging designs I have completed in quite awhile. It's just what you were looking for if you have alot of free time for working on a project =). This Harley Davidson design was intended to be cut 7' long with a CNC plasma cutting system(can be cut smaller with other CNC cutting systems). If anyone cuts this one out please repost an image. Enjoy!
Sincerely,
Jason Henry
Cascade Metal Designs LLC
http://www.customdxffiles.com
Sincerely,
Jason Henry
Re: Harley Davidson (lots of detail)
WOW......Absolutely awesome! Thanks for sharing Jason. Incredible detail.
- Loyd
Yes, indeed great job!
Thank you, hope all are well.
Loyd
Loyd
- tentonjj
holy crap!!!!!!!!!!!!! i think i just messed myself
Jayson Johnson
JMJ Graphix
920-517-7122
JMJ Graphix
920-517-7122
wow my 1250 hyperther will have a melt down thanks for ur art work
1128 pierces! Holy Moly
Looks nice though.. would like to see pics of this one cut out.
ColdCreekWorks.com
ColdCreekWorks.com
Very nice, thank you.
- GoingCustom
Put a little bit of time into it last night and a little bit more tonight... Hoping to have one roughtly 4x4 cut out by the end of the week! I'll take a pic and post it when I do!jdh239 wrote:1128 pierces! Holy Moly
I wanted to try my new ball point pen holder. It took about an hour at 11 ipm. I forgot to clean off all the fingerprints first, that might've worked a little better.... That's a lot of cuts. The drawing itself is nice and clean but I'm slightly wondering if it can be cut, and will lay flat, and support itself. If so, it will be interesting to see...
Hi Everyone, This is my first reply post just cut the Harley Cop it took 2hrs cut time came out pretty good lost the horn and needs some tack welding on back for strength purposes it will look great after black chrome powder coat Thanks for awsome drawing. Going to put on the wall of my shop.
- FreeDXF.com
I was wondering how large the design work was that was cut out? This image was intended to be cut 7' long if cut with a plasma cutting cnc system. The design work should stay intact as long as your cut width doesn't exceed .08". Heat build up may be problematic but can be reduced with a water tray. JH
it is worth noting there are some thin spots and if you shrink it to fit on a smaller table it might not be possible to cut smaller
Last edited by SignTorch Vector Art on Fri Mar 09, 2012 5:40 pm, edited 1 time in total.
Hi Jason, You are correct i scaled down size to a 4 ft table and was trying to cut with out with out reordering cut paths not thinking i did have heat warp problem. Going to adjust a few areas and go again your drawing is still awsome it would have cut perfect the first time if would have been thinking instead of rushing my fault Thanks for great file Mike F
- FreeDXF.com
I believe that this design would work the best if it were cut and fastened to a wall. Due to the numerous interior cuts the rigidity of such a large design piece would not be very suitable for producing a free standing piece of design work. In addition I believe the design work might also work well if hung from a ceiling (albeit a tall ceiling). This design work will definently flex if not supported adequately after being cut out as pointed out by Gary. When designing artwork I always try to pay close attention to how close my cut paths are to each other. Some areas of the design work you will find cut paths extremely close to each other and that is alright as long as that particular section is not critical for keeping the design work from falling apart. It is always a good practice to inspect the design work in it's entirety to look for areas that may cut out unexpectedly. If you do discover a section of design work that looks problematic you can isolate that particular section of design work and test the cut on a scrap piece of material. JH
Spectacular, thanks a million Jason!
- FreeDXF.com
Glad you all like the design work. Anyone have a picture they can share of how the design work cut out? I would be very interested to see how it all cuts out. JH
me to, your new sig is so much better than the old onetentonjj wrote:holy crap!!!!!!!!!!!!! i think i just messed myself
- tentonjj
Thanks Gary...............thats cool since you know so much about design!SignTorch Vector Art wrote:me to, your new sig is so much better than the old onetentonjj wrote:holy crap!!!!!!!!!!!!! i think i just messed myself
Jayson Johnson
JMJ Graphix
920-517-7122
JMJ Graphix
920-517-7122
Re: Harley Davidson (less detail)
... drawn 8 inches wide, scale 3x for plasma
- twicecustom
it lasered nice into wood
Jack of all trades, Master of none.
Benjiman
Benjiman
- Dustan
thanks for the image
- OSAFTW
SUPERB DETAIL!!!! Awesome work on both drawings!! thanks for the wonderful work!!!
Digger
OutriderOffroad.com / FlyingCowboys.net
Plasma Route 4x4
Thermal Dynamics A-40
artCAM - TurboCAD - MicroStation / SheetCam / Mach3
Plasma Route 4x4
THANKS FOR SHARING
Thanks for the Cycle Jason,
Have a birthday present that wont be returned!!
Aird
Aird
