Large Deer Scene
Re: Large Deer Scene
Can anyone convert this file so it it is not one huge object? Ungroup it?
- John Frantum
BVW1993, if you select the entire image and "explode" it, you should be able to move parts around or copy desired areas.
- John Frantum
Here, I exploded it for you, but now it has about 6 million nodes:
Thanks for sharing.
Very nice Thanks for the share
thanks for the share
Very nice file. Thanks for sharing. Just curious what size you recommend for the finished cut so that all of the detail remains intact?
Thanks again for a great design.
LDR 4'x4' Water Table
Command CNC Linux Controller
InkScape / SheetCam
InkScape / SheetCam
- gslavik
Nice work, Thank you for sharing!
Awesome File,Thank You
Beautiful Thanks
Thank you very nice
THANK YOU!
Thank you for the file it looks great.
Great, thanks
A customer wanted a mountain scene with deer and bears so i dug this one up and modified it. This will be wrapped around a bar with no backing so that is the reason for changing how it is cut. It cut well at its current 57.75 length x 22.5 height for the middle section. there was one unintended drop that happened in between the middle deer's legs but i went back and fixed that in the file.
Awesome edits to John's awesome original design. Well done and thanks for sharing that with us
amazing thank you
very nice!! Thank you Sir
Thanks for sharing!
Outstanding work! This looks really great and should come in handy for the future.John Frantum wrote: ↑Wed Feb 13, 2019 6:23 am Here is a scene you might be able to use.
Large deer scene 2.dxf
very nice, Thank you
- Kaos
Nice work.
Samson 5x10
Designedge software
Hypertherm Powermax 65
Hypertherm powermax 380
Thermodynamics cut master 85
Jet 4' box & pan break
Eastwood Powder coating guns.
Designedge software
Still getting some luv here in 2023 thanks for sharing.
This is great! Thanks for the design.
