.tap to dxf?
.tap to dxf?
Curious has anyone successfully converted a .tap file back to dxf? I cut a standing deer in a sawblade awhile back and all i can locate is the .tap file..
or is there a way to resize a .tap file? appreciate any help
Re: .tap to dxf?
I don't think you will find that conversion, the .tap has extra info added to it.
What you could try is to take a picture of it against a flat background and do a trace in Inkscape and resize it to create a new DXF file.
Re: .tap to dxf?
I think it was just a file I found online somewhere was just curious if it was possible
- ROKCRLER
Re: .tap to dxf?
If youre using sheetcam, you can import the .tap file and then scale it to the size you want then rerun the post.
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Re: .tap to dxf?
Re: .tap to dxf?
Got it!
- ROKCRLER
Re: .tap to dxf?
Ok I got the same as the first image, please explain the steps you used. I tried using .TAP files that I generated with SheetCam.
- ROKCRLER
Re: .tap to dxf?
Tom in sheetcam, import the tap file as gcode instead of excellon and it should open up.
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Re: .tap to dxf?
Thanks Rokcrler I had tried to use the .tap just below it, you can teach an old dog new tricks.
I'm sure it will be handy to use.
Re: .tap to dxf?
I did end up taking a pic off the screen and used Inkscape to trace it.. still better than starting from scratch as I couldn't even find the image
- ROKCRLER
Re: .tap to dxf?
Here is how I do it:
Dont forget to note down the post you normally use... dont ask how i know...
- import tap file
- setup operations
- In sheetcam, go to Options, Machine, Select DXF post
- Save the file and open with your DXF program
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Re: .tap to dxf?
Dude if that works your my new hero
- Double S Farms
Re: .tap to dxf?
ROKCRLER: Trying this with a .nc file thinking it should be similar but having no success. Importing as .nc get nothing. As Gcode get image, but can't get DXF to generate. Also tried changing suffix on file to .tap. Unable to attache .nc file - nor the .tap file - "ineligible file types". File is from Langmuir Fire Share. Any advice appreciated.
- ROKCRLER
Re: .tap to dxf?
I downloaded this file from fireshare, import in sheetcam with gcode, put all the inside on Inside layer and the outside on outside layer then ran the post (make sure you change it to DXF).
Opened the file in Qcad. It still needs some cleaning up like the lead in/outs.. but we have a dxf from .nc now.
Imported to Sheetcam: Cleaned up in QCad (removed rapids and lead ins) : Imported to Sheetcam for operations (I did have to scale it to get the insides to cut):
I attached both the .NC and DXF. For the .NC, remove the extra .dxf extension after .NC
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
- Double S Farms
Re: .tap to dxf?
ROKCRLER: Thx for your quick response and your patience. But, I'm still missing a step somewhere. Tried it with the 1001 usa 20 ipm2.nc file and with the one I want and no dxf in either case. Sheetcam window and Zip file for image I'm working on are attached (I hope).
Looking at your examples, I am expecting to wind up with a file ending in .dxf and just not getting there. If you've got the time to take a look at these, I'd sure appreciate your help.You currently do not have access to download this file.
- ROKCRLER
Re: .tap to dxf?
I downloaded your file
Extract/Unzip
Import in sheetcam Separated parts into layers, Inside and Outside and deleted the extra lines. you might have to extend some lines on some parts, I did. I hope that helps, i can do a video if you need me to.
Extract/Unzip
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
- Double S Farms
Re: .tap to dxf?
You are the man! Thanks to you and Mike Caffey, file originator, looks like the six year old mechanically inclined great-grandson is going to have a nice birthday present. And, yes, if you have time video would be great. I'd like to know: 1) what I am missing to get the DXF and 2) how I can do this in the future for other projects.
- ROKCRLER
Re: .tap to dxf?
Rokcrler - thanks for that great explanation. I don't use Sheetcam - but for many here who do this is a very handy method for recovering lost dxf files from existing nc files.ROKCRLER wrote: ↑Fri Jun 02, 2023 6:03 pm I downloaded your file
Extract/Unzip
Import in sheetcam
Re: .tap to dxf?
Double S Farms - here is another method I have used in the past with great success that does not involve Sheetcam.Double S Farms wrote: ↑Fri Jun 02, 2023 5:26 pm ROKCRLER: Thx for your quick response and your patience. But, I'm still missing a step somewhere. Tried it with the 1001 usa 20 ipm2.nc file and with the one I want and no dxf in either case. Sheetcam window and Zip file for image I'm working on are attached (I hope).
contraption-toilet-paper-holder 1.zip
Step 1 - download and install G-Code Ripper (free download).
https://www.scorchworks.com/Blog/g-code ... de-ripper/ Step 2 - Open G-Code Ripper, set to Export (DXF, CSV)
Step 3 - Open the G-code file
Step 4 - Export as DXF
Re: .tap to dxf?
Once you have downloaded and installed G-Code Ripper, here is a step-by-step explanation of how to use it.
Re: .tap to dxf?
Once you have the dxf, use your vector editor of choice to edit out rapid moves and lead-ins and save for import to Sheetcam or your cam program of choice. Here I have showed editing the file with Inkscape, but other programs such as the one Rokcrler used will work as well.
Re: .tap to dxf?
Thanks David as usual a very detailed tutorial on using other software.
