lubricating rack and pinion or not?
Tristar500
Post by Tristar500 »
I recently rebuilt a salvaged CandCNC table with rack and pinion drive. Build my own controller based on Mach 3 with ESS and THC-2 from CNC4PC.
What do you all think about running some sort of lubrication on the gear rack for a system like this and if using lube, what do you recommend?
Thanks all!! :Yay
5X7, 6x11 plasma own design
Mach3,4 SheetCam, CorelDRAW 2020 Inkscape .0.92
Homebuilt 3 axis mill
Homebuilt 5 axis mill
PrimeWeld cut 60
Hypertherm 350
Miller Symchrowave 250 DX
Several mig welders
You are only as old as the woman you feel.
Re: lubricating rack and pinion or not?
I have a rack on one of my axis and do run some lube on the rack, not a lot just enough for smooth operations. Watch for dusk built up, not much does happen as the rack is high away from the action.
bLouChipBlacksmith
Post by bLouChipBlacksmith »
I run this, it makes a huge difference. Almost total elimination of gear mesh noise.
Dry lube for sure or metallic dust will build up on the rack and it will counterproductive.
tinspark
Post by tinspark »
ditto on the dry lube. i use dry lube on my system
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
N2 Welding
Post by N2 Welding »
bLouChipBlacksmith wrote: Sat Dec 02, 2023 10:14 pm I run this, it makes a huge difference. Almost total elimination of gear mesh noise.
Is this a WD-40 stuff considered a dry lube?
weldguy wrote: Mon Dec 04, 2023 11:20 am Dry lube for sure or metallic dust will build up on the rack and it will counterproductive.
tinspark wrote: Tue Dec 05, 2023 10:52 am ditto on the dry lube. i use dry lube on my system
Are y’all talking about stuff more like a graphite lube that is painted on and dries in the air. We used that on the deck tubes that slide up/down in/out for car haulers. Ironically the stuff was called slide or something like that.
EDIT:
Stuff was called EZ Slide. I see another brand called Slip.
tinspark
Post by tinspark »
Regular WD-40 is not a dry lube, but they do make a dry lube (see below) This is the stuff that a lot of guys use around here. a spray can is easy to use and should last a while. I really only use the dry lube for my CNC machine for the gear rack and exposed bearings on my CNC machine etc. But keep a gallon of regular WD-40 around to lube all sorts of stuff around the shop and home.. Dry is harder to find, so I always just order online..
Here is an Amazon link . $8
Doug,
Hypertherm 45XP-
Tristar500
I ordered the WD dry.
Thanks all!!
PrimeWeld cut 60
Hypertherm 350
Several mig welders
N2 Welding
Ok thanks guys. That PTFE is what scares me :/
