I have been having no torch fire intermittently. I have jumped pins 3 & 4 to get a manual torch fire., tested continuity and it tests fine just no fire running Mach 3.
The programming is fine.
I walk away for a while when I come back it will start.
It's doing my head in.
Intermittent torch fire problem
Mick
Owner/ operator
MJT rural Contracting
Weldclass t1200
Hypertherm Pwermax 45XP
Owner/ operator
Weldclass t1200
Re: Intermittent torch fire problem
how are you firing the plasma?
you are supposed to use dry contacts (IE a relay with contacts), not a solid state relay, MOSFET, etc.
With Mach 3 you can test fire the plasma with a F5 on/off each click. You also need the output pin set and that output shown in the M3 selection.
All the settings are good. I'm wondering if my board could be going bad from heat. I put a temp gun on components and they were running at over 40°C. Not sure what they should be running at.
Mick
Owner/ operator
Weldclass t1200
Owner/ operator
Weldclass t1200
Most components are rate to at least 100C although I typically design to 80c taking into account things like the internal temp of power components versus the case tempo and things like ambient temps and air flow
One real easy way to find thermal problems is to use a hair dryer and force things to heat up . If they start to constantly fail when hot then if you cool them down and they start to work you have a thermal failure.
I assume there is noting at the torch interface to show the fire status? It sure helps if there are indicators . the problems is evena short glitch will cause the torch to go out and most will not restart until you remove the fire signal for a longer time.
