stv vs arc light
mkrich601
stv vs arc light
Post by mkrich601 »
would you guys let a steel gantry and welded frame(stv) vs a aluminum gantry and bolted frame ( arc light) be a deciding factor.
me being a welder first I like the welded Frame but stv uses myplasmacnc software and arc light uses sheet cam. I like the arc light but can't wrap my head around a bolted together frame. also arc light has more features I can add later if I want. stv does not. pros and cons please.
Re: stv vs arc light
I have always used a welded frame for durability on the tables I built. With the forces being used to move the X and Y axis at speed bolts could have a habit of getting loose over time.
That's a tough one. STV does offer welded tables now and for half the price of the ArcLight. I have not compared options but I suspect the STV is pretty stripped down for that price. ArcLight has been around much longer and their build quality is pretty impressive. If it were me and I was choosing between the 2, I would get the Arclight unless STV was local to me. Are either of these brands local to you?
mkrich601
Post by mkrich601 »
No neither are no where near me.
Where are you located? Always nice to check out anyone local first.
mkrich601
Post by mkrich601 »
The only thing is Stv doesn’t have any accessories to add. Table wise they have the same options. My real concern is don’t know if I can add a aftermarket or self fabricated air scribe to Stv’s my plasmacnc software. Only thing they offer in scribes is hypertherm ez scribe
mkrich601
Post by mkrich601 »
South Mississippi
I don't know of any brands out your way. I have read elseware that the stv software does not make it easy if not impossible to add an option like and air scribe. I would be leaning towards the Arclight. Which model are you looking at, so many now. Post a link to it if you can.
mkrich601
Post by mkrich601 »
The ability to add an air scribe later would be really nice. But I don’t understand why it would be impossible to add to Stv
That is the Arclight I was looking at, the STV is different and that is a nice looking unit as well. I would still go Arclight, more time in business, have a great reputation, and they are not shy about zooming in on all of the detail features of the table for you to see where I cannot see past the outer skin on the STV pretty much.
SegoMan DeSigns
Post by SegoMan DeSigns »
When properly bolted & braced the frame will be plenty stout enough.. The trouble with welding is heat causes warp and very few companies have access to what BTA does here:
https://www.plasmaspider.com/viewtopic.php?t=36465
