Rollout wheel
Rollout wheel
Does anyone have cut paths for a rollout wheel tia
Re: Rollout wheel
What does it do ?
Looks like there might be a 2" receiver hitch at the right end.
Re: Rollout wheel
lathe chuck Gets mounted for pipe work
- tinspark
Re: Rollout wheel
well that is certainly a pretty cool gizmo!
I guess it spins manually? didnt see a motor
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
Re: Rollout wheel
It appears the screen shot is a CAD Model, the OP should easily be able to pull the flat patterns off of it as .dxf files.
Re: Rollout wheel
Nope! The OP provided a screen shot from here. The seller does not provide plans or solid model for obvious reasons.
https://vpmfabrication.com/products/vpm-8-rollout-wheel
Re: Rollout wheel
Would this be a problem with theft of design on here ?
Re: Rollout wheel
The seller does not offer the design for sale. So no solid model. I would expect that if someone were to reverse engineer the seller's design and offer it here, it would be as you say "theft of design".
Re: Rollout wheel
I'm new here, but that's just what I was thinking too.
