DXF Help
Re: DXF Help
Thank you, David, I'm going to probably spend some time this weekend playing with it and seeing what I can come up with. I really appreciate it. I definitely need to play around with some of the other programs and maybe play with doing artsy stuff.
Re: DXF Help
Also, probably the wrong part of the forum to ask but I'm using MyPlasma and their cad program MyMiniCad for some of my drawings I'm doing, I tried to share a couple, but they are saved as .2d format. Is there an easy way to convert to a .svg or .dxf file so I can share them with everyone.
Re: DXF Help
What file export options does it offer? Perhaps show a screen shot of the export options drop down tab.zakscott22 wrote: ↑Wed May 15, 2024 7:49 pm Also, probably the wrong part of the forum to ask but I'm using MyPlasma and their cad program MyMiniCad for some of my drawings I'm doing, I tried to share a couple, but they are saved as .2d format. Is there an easy way to convert to a .svg or .dxf file so I can share them with everyone.
Re: DXF Help
I don't think anyone ever asked - but what program are you using to do your trace? Were you trying to trace by hand or auto trace? When you say that you're getting rounded corners that leads me to believe you are using auto trace.zakscott22 wrote: ↑Sun May 12, 2024 3:21 pm I have been trying to convert this into a DXF file to cut for my local fire department, everytime i try to trace it i can not get a clean file that will look ok when being cut. Alot of the corners and what should be sharper edges get more rounded and kinda looks sloppy to me. I have asked for a better looking file but this is the best they have given me. Can someone help me, im not even sure if this is the right location to ask for this.
Re: DXF Help
https://www.proma-elektronika.com/downl ... iCADen.pdfzakscott22 wrote: ↑Wed May 15, 2024 7:49 pm Also, probably the wrong part of the forum to ask but I'm using MyPlasma and their cad program MyMiniCad for some of my drawings I'm doing, I tried to share a couple, but they are saved as .2d format. Is there an easy way to convert to a .svg or .dxf file so I can share them with everyone.
Re: DXF Help
/adbuch wrote: ↑Thu May 16, 2024 3:56 amI don't think anyone ever asked - but what program are you using to do your trace? Were you trying to trace by hand or auto trace? When you say that you're getting rounded corners that leads me to believe you are using auto trace.zakscott22 wrote: ↑Sun May 12, 2024 3:21 pm I have been trying to convert this into a DXF file to cut for my local fire department, everytime i try to trace it i can not get a clean file that will look ok when being cut. Alot of the corners and what should be sharper edges get more rounded and kinda looks sloppy to me. I have asked for a better looking file but this is the best they have given me. Can someone help me, im not even sure if this is the right location to ask for this.
So I was using auto trace in inkscape. When you say hand trace what do you mean?
Re: DXF Help
well that sucks, i guess im gonna have to start drawing in fusion360 or somethingadbuch wrote: ↑Thu May 16, 2024 4:02 amhttps://www.proma-elektronika.com/downl ... iCADen.pdfzakscott22 wrote: ↑Wed May 15, 2024 7:49 pm Also, probably the wrong part of the forum to ask but I'm using MyPlasma and their cad program MyMiniCad for some of my drawings I'm doing, I tried to share a couple, but they are saved as .2d format. Is there an easy way to convert to a .svg or .dxf file so I can share them with everyone.
Re: DXF Help
Auto Trace examplezakscott22 wrote: ↑Fri May 17, 2024 5:58 pm/adbuch wrote: ↑Thu May 16, 2024 3:56 amI don't think anyone ever asked - but what program are you using to do your trace? Were you trying to trace by hand or auto trace? When you say that you're getting rounded corners that leads me to believe you are using auto trace.zakscott22 wrote: ↑Sun May 12, 2024 3:21 pm I have been trying to convert this into a DXF file to cut for my local fire department, everytime i try to trace it i can not get a clean file that will look ok when being cut. Alot of the corners and what should be sharper edges get more rounded and kinda looks sloppy to me. I have asked for a better looking file but this is the best they have given me. Can someone help me, im not even sure if this is the right location to ask for this.
Hand Trace (manual trace) example
Re: DXF Help
For mechanical parts, Fusion 360 could be a good choice. Inkscape and CorelDraw would work as well. For more artistic pieces such as the original image you posted - Inkscape, CorelDraw, or Adobe Illustrator would probably be better than Fusion 360. I expect that Ben did his "manual drawing" of your image using TMCad, or maybe CorelDraw. I did my work on it using a combination of Inkscape, AI, and Design Edge.zakscott22 wrote: ↑Fri May 17, 2024 6:03 pmwell that sucks, i guess im gonna have to start drawing in fusion360 or somethingadbuch wrote: ↑Thu May 16, 2024 4:02 amhttps://www.proma-elektronika.com/downl ... iCADen.pdfzakscott22 wrote: ↑Wed May 15, 2024 7:49 pm Also, probably the wrong part of the forum to ask but I'm using MyPlasma and their cad program MyMiniCad for some of my drawings I'm doing, I tried to share a couple, but they are saved as .2d format. Is there an easy way to convert to a .svg or .dxf file so I can share them with everyone.
Inkscape is free - so that would probably be my recommendation to get you started. You can certainly draw plates, brackets, etc. using Inkscape. Then save as dxf for import to your myplasm program for cutting. Also - your myminicad program will work fine for drawing simple shapes like brackets, etc. that you have probably already been doing.
Re: DXF Help
Here is an Inkscape manual trace screen shot sequence to show how to use the Bezier draw tool to hand trace an image.
Re: DXF Help
And here is another one. Let me know if you have any questions about this process and I will try to answer them.
Re: DXF Help
- ben de lappe
Re: DXF Help
One hand traces an image by placing nodes individually and adjusting them to suit as David has done in his well thought out samples. It takes practice but once you get the hang of it the results are so much better versus simply relying on a trace and straightening it out.zakscott22 wrote: ↑Fri May 17, 2024 5:58 pmSo I was using auto trace in inkscape. When you say hand trace what do you mean?
Yes David, for the sake of expediency I used TM CAD here. As always hand traced and looking like they always will be as I venture deeper into CorelDraw and continue to learnadbuch wrote: ↑Fri May 17, 2024 6:18 pmFor mechanical parts, Fusion 360 could be a good choice. Inkscape and CorelDraw would work as well. For more artistic pieces such as the original image you posted - Inkscape, CorelDraw, or Adobe Illustrator would probably be better than Fusion 360. I expect that Ben did his "manual drawing" of your image using TMCad, or maybe CorelDraw. I did my work on it using a combination of Inkscape, AI, and Design Edge.zakscott22 wrote: ↑Fri May 17, 2024 6:03 pmwell that sucks, i guess im gonna have to start drawing in fusion360 or somethingadbuch wrote: ↑Thu May 16, 2024 4:02 am
Re: DXF Help
zakscott22 - Since you mentioned drawing in Fusion 360 - here is an example showing how to do a manual trace using Fusion 360. Fusion 360 does have a very nice Spline tool for manual tracing - very similar to the CorelDraw B-Spline tool that I like to use, and quicker to use than the Inkscape Bezier draw tool.zakscott22 wrote: ↑Fri May 17, 2024 6:03 pmwell that sucks, i guess im gonna have to start drawing in fusion360 or somethingadbuch wrote: ↑Thu May 16, 2024 4:02 amhttps://www.proma-elektronika.com/downl ... iCADen.pdfzakscott22 wrote: ↑Wed May 15, 2024 7:49 pm Also, probably the wrong part of the forum to ask but I'm using MyPlasma and their cad program MyMiniCad for some of my drawings I'm doing, I tried to share a couple, but they are saved as .2d format. Is there an easy way to convert to a .svg or .dxf file so I can share them with everyone.
Re: DXF Help
Re: DXF Help
No kidding. Pretty cool. Never tried to trace anything in Fusion before, thats pretty slick David, thanks.
Re: DXF Help
The OP mentioned he might have to use Fusion 360, so I thought I would show him an example. It's really pretty simple to do, and the only downside of Fusion 360 is that it is "cloud based" and sometimes has lags/delays in processing in real time.plasmanewbie wrote: ↑Tue May 21, 2024 10:04 am No kidding. Pretty cool. Never tried to trace anything in Fusion before, thats pretty slick David, thanks.
Re: DXF Help
I have noticed that lag sometimes, it's pretty irritating and with complex designs it can be a looooong time.adbuch wrote: ↑Tue May 21, 2024 11:59 amThe OP mentioned he might have to use Fusion 360, so I thought I would show him an example. It's really pretty simple to do, and the only downside of Fusion 360 is that it is "cloud based" and sometimes has lags/delays in processing in real time.plasmanewbie wrote: ↑Tue May 21, 2024 10:04 am No kidding. Pretty cool. Never tried to trace anything in Fusion before, thats pretty slick David, thanks.
Re: DXF Help
Thank you for showing how to hand trace in those programs, I am definitely going to have to find time to sit down and just play with it all. I took autocad in high school back in the early 2000s so just trying to get back into it and figure it all out.adbuch wrote: ↑Tue May 21, 2024 11:59 amThe OP mentioned he might have to use Fusion 360, so I thought I would show him an example. It's really pretty simple to do, and the only downside of Fusion 360 is that it is "cloud based" and sometimes has lags/delays in processing in real time.plasmanewbie wrote: ↑Tue May 21, 2024 10:04 am No kidding. Pretty cool. Never tried to trace anything in Fusion before, thats pretty slick David, thanks.
Re: DXF Help
That probably would have been AutoCAD Release 14, or maybe AutoCAD 2000. I started out using AutoCAD R14 in 1997 and still use it today for certain tasks. It won't run on Windows 7 or 10, so I've got it installed onto several older computers running Windows 2000 and Windows xp. It would not be useful for image tracing, but is great for mechanical drawings, etc. But if you were proficient with AutoCad, it should be easier for you to learn some ot the newer drawing programs. Let us know which program you decide to learn and be sure to ask if you have any questions about it.zakscott22 wrote: ↑Wed May 22, 2024 8:31 pmThank you for showing how to hand trace in those programs, I am definitely going to have to find time to sit down and just play with it all. I took autocad in high school back in the early 2000s so just trying to get back into it and figure it all out.adbuch wrote: ↑Tue May 21, 2024 11:59 amThe OP mentioned he might have to use Fusion 360, so I thought I would show him an example. It's really pretty simple to do, and the only downside of Fusion 360 is that it is "cloud based" and sometimes has lags/delays in processing in real time.plasmanewbie wrote: ↑Tue May 21, 2024 10:04 am No kidding. Pretty cool. Never tried to trace anything in Fusion before, thats pretty slick David, thanks.
