Hypertherm fine cut consumables.
Information on plasma cutting nozzles, electrodes, and other consumables.
Metal Lee
Post by Metal Lee »
Hello all just wondering if any one has tried these consumables?
I am using a Powermax 600 and I am trying to get a thinner curf,normal amps is 40 and materal thickness is 16 to 11ga. Any input would be apreciated,Thanks for your time.
Thanks, Metal Lee
Keep the sparks out of your boots!
jcfreer
Re: Hypertherm fine cut consumables.
Post by jcfreer »
i have used the fine cut on 1/4 material with great results
jeeplogic83
Post by jeeplogic83 »
I use my fine tips for 1/4 in to 24 ga copper as a rule you don't go past 40 amps or you will burn tips. The fine tips work great for just about all cutting.
Nitro
Post by Nitro »
Torchmate wrote:14 gauge is the thinnest I have used but I can use a 20 amp drag tip and set the kerf to a thin line and it makes a thin cut works well with thin metals
I cut 18 ga CRS almost exclusively and use the fine cuts with a powermax 1000 (no torch height control) with good results set at about 30 amps. I'm curious, what's a 20 amp drag tip?
Metal Lee
Post by Metal Lee »
Thanks All.
Thanks, Metal Lee
Return to “Plasma Consumables”
